Cardboard to prevent ice on windshield
by Corollaman - 11/22/19 01:18 PM
Bond Arms Rowdy
by faltic - 11/22/19 01:12 PM
Question about stored vehicles
by loneryder - 11/22/19 12:53 PM
Camry exhaust downpipe
by supton - 11/22/19 12:30 PM
What is your favorite airline and why?
by ZZman - 11/22/19 11:35 AM
Costco Instant rebate for M1
by Joephu - 11/22/19 11:25 AM
Serpentine belt
by Grambo - 11/22/19 10:50 AM
My 2016 Ford Fiesta Failure
by Mr_Luke - 11/22/19 10:37 AM
Starter Tool set - hand tools for professional work?
by btanchors - 11/22/19 10:20 AM
Acceptable amount of time to get up to speed?
by ls1mike - 11/22/19 09:35 AM
Paint question
by supton - 11/22/19 09:31 AM
SUV tires vs passenger car tires
by Ded Mazai - 11/22/19 09:00 AM
Crysler Crossfire Pro/Con?
by tc1446 - 11/22/19 08:54 AM
Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69938 Registered Users
94 registered members (Audios, bbhero, 1960Elco, 97f150, 2015_PSD, 69Torino, 7 invisible), 2,351 guests, and 35 spiders.
Topics297,780
Posts5,122,411
Members69,938
Most Online3,589
Nov 2nd, 2019
Rate Thread
Page 2 of 4 1 2 3 4
Re: Barrel cleaning pros and cons [Re: The_Eric] #4968610 01/03/19 09:31 AM
B
billt460 Offline
B
Originally Posted by The_Eric
While I appreciate the input, I'm not looking for cleaning tips, tricks or preferred products. Just pros and cons of cleaning religiously vs not cleaning.
Why go to either extreme? Clean when you feel the weapon needs it. Or when accuracy starts to fall off to an unacceptable level in a long range weapon. You don't have to do anything "religiously", as opposed to not doing anything at all.
Re: Barrel cleaning pros and cons [Re: The_Eric] #4968635 01/03/19 10:04 AM
stockrex Offline
Ask yourself why clean? it is like exfoliating your skin, do you do it everyday? every other day? or when your girlfriend points out the flaking dead skin laugh.
I am the sole member and president of "Dad's against cleaning barrel" club. So my 2 cents is not unbiased.
I shoot off hand, prone with/without sling. I only clean with a dry path mostly to make sure the barrel is unobstructed.
If you clean your gun, shoot some fouling shots to get dirty again.
Barrel breakin is like tire flush or blinker fluid, people are too emotional about this just like damage to crown and accuracy.
Bottom line, know your weapon, it will tell you when it needs to be cleaned,
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Barrel cleaning pros and cons [Re: The_Eric] #4968639 01/03/19 10:08 AM
W
WyrTwister Offline
W
If corrosive ammo , clean by that night .
It depends on the ammo , the climate & weather conditions , the weapon , etc.
I do not see a hard & fast / universal answer .
If you wish to be xautioue , clean every time you shoot it .
Wyr
God bless
Re: Barrel cleaning pros and cons [Re: billt460] #4968687 01/03/19 11:19 AM
T
The_Eric Offline OP
T
I can accept that type of answer. It seems like a good practical approach.
Do you ever run a lightly oiled patch through prior to storage or does the copper deposits (or lead) seal the steel well enough that rust isn't an issue?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Barrel cleaning pros and cons [Re: The_Eric] #4968877 01/03/19 02:31 PM
B
billt460 Offline
B
Yes, I always finish with a well oiled patch down the bore.
Re: Barrel cleaning pros and cons [Re: stockrex] #4968886 01/03/19 02:39 PM
K
Kamele0N Offline
K
Ask yourself.....what do you do after you "relive" yourself on the toilet! Do you clean it every day? every other day? or when your girlfriend points out that you smell strange smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Barrel cleaning pros and cons [Re: billt460] #4969503 01/04/19 08:21 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
IMO there’s a fine mix there. Cleaning “religiously” opens up the slight chance of damaging something, whether a muzzle crown, small bits of metal from cartridge manufacturing, etc. who knows. It also opens up the exposure to fairly strong chemicals in some cases.
I think your recommendation of bore tech, especially if a more religious cleaning outlook is considered, is prudent as I find their water based chemicals and their bearing rods to be the best I’ve encountered. It allows a more comfortable and safer cleaning experience, regardless of tempo.
This I think is a more important and fundamental question. Oil over the junk left behind, if not doing a rigorous cleaning, or not? Oil is your friend, at least until it creates its own fouling or affects the first shots next time.
Ive personally thought about getting those Uber cheap bore snakes from Amazon, and using one as an oily post-shooting version, another (perhaps with the brush removed) as a cleaner before taking the first shot next time. This way you can scrub a little and leave some oil behind when done, and then dry it up next time. Sure beats getting out rods and jags and patches and taking the firearm apart just to run one patch... not there yet though...
Re: Barrel cleaning pros and cons [Re: The_Eric] #4969671 01/04/19 12:05 PM
H
HangFire Offline
H
What is the effect of the bullet lube on the barrel? Does it serve as a protectant?
Yes, but it is not a perfect protectant.
With clean burning powders and storing in low humidity, and a smooth, quality bore, 22LR shooters like pro competitor Lones Wigger could go years between cleaning.
On the other hand, if you have a 38 revolver that spits a bit and you're using up old powder, and store the gun in higher humidity, the suspended powder residue in the lube may transmit humidity to the bore and cause rust.
So the answer there is "depends".
Various musings: http://hangfire.net
Re: Barrel cleaning pros and cons [Re: The_Eric] #4991303 01/26/19 09:51 AM
CT8 Offline
I clean my range guns when they start to soil my clothing or start to malfunction from the crud. I'll oil them as needed. Scrubbing the barrel? only when the accuracy drops off.. We cause more wear scrubbing than shooting.
Re: Barrel cleaning pros and cons [Re: AZjeff] #5019615 02/21/19 10:55 PM
Marco620 Offline
Nope. Just live close by and like our Kansas ties to CZ and Hoppes. Love any business that comes to Kansas.
15' Civic 1.8 i-vtec 288,000 mi Mobil 0w30 & LG Biotech, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Honda,Doberman,CZ's & SONY Aficionado
Re: Barrel cleaning pros and cons [Re: The_Eric] #5019778 02/22/19 07:11 AM
Astro14 Offline
Love the smell of Hoppes.
Reminds me of when I was young, and my uncle and cousins would clean their rifles on the kitchen table at our farm in PA...
I even bought my kid brother Hoppes air fresheners for his truck a few years ago.
He totally loved them. He's got the same memories...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Barrel cleaning pros and cons [Re: The_Eric] #5019796 02/22/19 07:27 AM
Pablo Offline
I soak really fouled parts (when necessary). Heavily used AR bolt, for example. Soak overnight in Hoppe's/Kroil for example, then brush very clean. Same principle with a bore, of course overnight not necessary. I usually clean 4-5 guns at a time. So I start with a fairly wet mop off all the barrels and let it sit while I clean all the small parts. Often I will mop it again in the middle of cleaning the other parts, then just a lube blast, a couple dry patches and the barrel is quite clean.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Barrel cleaning pros and cons [Re: Astro14] #5020041 02/22/19 10:46 AM
T
Triple_Se7en Offline
T
Not sure what Hoppes solvent smells like today. But the Hoppes from 1950-2000 was terrible to smell.
There are really good products today that are non-toxic, non-smelling and safe on the hands & safe on the environment. Google search is your best friend for that.
19 Hyundai SantaFe 2.4GDI Valv Syn 5w30 / NAPA O/E filter / 6oz Liqui-Moly Treatment
20 Kia Soul X-Line 2.0 non-turbo / Factory-fill oil / filter
04 Colorado 3.5 / Castrol Edge 0W40 Euro / K&N filter
Re: Barrel cleaning pros and cons [Re: Triple_Se7en] #5020139 02/22/19 12:24 PM
Astro14 Offline
Sure there are.
On my bench are the following cleaning products:
- CLP (various, old and new Safariland formulations, not that great on bores, keep a bottle in my range bag)
- Ballistol (another CLP, smell is OK, doesn't work too well on bores, use it to wipe down firearms and axes)
- MPro7 Gun cleaner (not much smell, doesn't seem to work well on bores)
- AMSOIL Firearm Cleaner (love it. Great stuff. The solvent cleans reasonably well and leaves behind just enough oil to prevent rust).
- Sweets 7.62 (horrible ammonia smell, works well, but ugh)
- Hoppe's Elite Bore Gel (works OK)
- Hoppe's Foaming Bore Cleaner (works well, makes a mess)
- Butch's Bore Shine (mild smell, cleans great, probably my favorite)
- Hoppe's No.9
And I still like the smell of Hoppe's...
LOL
32 Packard 15W40
05 MB S600 0W40 M1
Re: Barrel cleaning pros and cons [Re: The_Eric] #5020648 02/22/19 08:46 PM
wwillson Offline
Administrator
Administrator
Best all around gun lube/cleaner I've ever used is Corrosion-X for guns. The guy who formulated it is a member here and used to work for Mobil. He explained to me one time his goals for the formulation. The corrosion protection is simply the best out there and the anti-wear characteristics are also extremely good. I've used it on the hinge of my BT-99, which now has hundreds of rounds of trap under its belt. The hinge is still so tight that some people ask me if I ever considered putting some lube on it.
Page 2 of 4 1 2 3 4
