Bobcat S630 engine oil
by Spdfrk1990. 07/18/19 12:09 PM
737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Any friends of StevieC here ?
by Kjmack. 07/18/19 09:29 AM
Oil change interval on 70 Chevelle
by 007. 07/18/19 09:20 AM
New to me 2018 Grand Caravan 3.6 weight questions.
by racinjason. 07/18/19 07:38 AM
Help With 6L80E Fluid & Pan Replacement
by Sierra048. 07/18/19 06:39 AM
98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
91 registered members (4WD, 1WildPig, 87sammy, 94MaxGXE, 2012AccentSE, ad244, 6 invisible), 2,172 guests, and 26 spiders.
Topics292,027
Posts5,015,486
Members68,699
Most Online2,967
Mar 10th, 2019
Air Compressor Oil #5019623
02/22/19 12:12 AM
02/22/19 12:12 AM
Michael_P Offline OP
Its been a week now since I changed oil on my DeVilbiss 6.5HP 240V air compressor. Ive had this compressor since new for 20 years, no issues. This compressor calls for SAE20 ND on the label on the compressor (No ISO recommendations). I try to guesstimate 100 hours of use, then change the oil. Last week I was in a rush and picked up some Amsoil air compressor oil at the local NAPA, not realizing the weight was ISO 100 (SAE 30/40) instead of ISO 46 (SAE 20). After draining the old oil and filling the compressor with the ISO 100, it seems to run quieter and fill the tank faster. This compressor is in a heated garage and will never operate under 60 degrees F, even if its minus 20 F outside. Are there any long term issues of running this (ISO 100, SAE 30/40) oil in my compressor that calls for SAE 20? If the consensus is to change to the recommended SAE 20, its no big deal. Oil is cheap and it takes 5 minutes to change. This compressor is used a fair amount for sand blasting and other continuous use tasks.
Thanks in advance
Re: Air Compressor Oil [Re: Michael_P] #5019639
02/22/19 12:26 AM
02/22/19 12:26 AM
Apple Valley, California
Chris142 Online content
Chris142  Online Content
Run it.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Air Compressor Oil [Re: Michael_P] #5019699
02/22/19 05:12 AM
02/22/19 05:12 AM
York, Pa
fozzdesy2001 Offline
York, Pa
If you want some great compressor oil try this DEWALT D55001 Synthetic Compressor Oil. Kind of expensive but it really helps with continuous running pumps.
https://www.amazon.com/DEWALT-D55001-Synthetic-Compressor-Quart/dp/B0008GLW9Y
2001 Subaru Forester S
Replaced with a 2006 Forester
2004 Subaru Forester XT
Death by deer. Replaced with 2003 Impreza Outback Sport (beater)
Re: Air Compressor Oil [Re: Michael_P] #5019717
02/22/19 06:22 AM
02/22/19 06:22 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
I purchased my compressor back in the 80's when I lived in the Midwest. The only problem I had with it, was when I used it in cold Winter weather. The oil in the compressor from the factory was too thick, and caused the breaker to trip. So I drained it and refilled it with Mobil 1 0W-30. (At least that's what I think it was. It was the thinnest Mobil 1 I could find at the time). It solved the problem, and the compressor would start and run on the coldest Winter days without a problem.
When we moved to Arizona it ran the same. I finally changed the compressor oil this past year. It drained out every bit as clean as it went in. I refilled it with the same 0W-30 Mobil 1. Even on 100F+ degree days, it never runs long enough, or hot enough for my use, to where I can't place my hand on the cylinder head. It's now 34 years old and still going strong. It gets run every time I clean my guns. Which is usually at least once a week.
Re: Air Compressor Oil [Re: Michael_P] #5019753
02/22/19 07:43 AM
02/22/19 07:43 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I have Royal Purple compressor oil in my 60 gallon compressor. It got good reviews here years ago. It works much better than it did with the factory fill in the cold weather, and much like billt460's compressor I can touch the cylinder head during summertime use
God Bless Our Troops
Re: Air Compressor Oil [Re: Michael_P] #5019765
02/22/19 08:02 AM
02/22/19 08:02 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Run the 30w under those operating conditions. FR Sport has Redline 20w and 30w on sale now for anyone needing it.
https://frsport.com/redline-31304-e...myrLP4AIVjI3ICh05YgXrEAQYBSABEgLPhfD_BwE
https://frsport.com/redline-31204-each-oil-31204-polycomp-20wt-compressor-oil-1-quart
Re: Air Compressor Oil [Re: Michael_P] #5019772
02/22/19 08:07 AM
02/22/19 08:07 AM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
Thanks in advance
No problem running it at your ambient temps.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Air Compressor Oil [Re: Trav] #5019789
02/22/19 08:20 AM
02/22/19 08:20 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Those are good prices for RL compressor oil.
Re: Air Compressor Oil [Re: demarpaint] #5019845
02/22/19 09:21 AM
02/22/19 09:21 AM
Trav Offline
Trav  Offline
Yep, I got 5qts of the 30w, 4 for the sump and 1 to top off.
Re: Air Compressor Oil [Re: Michael_P] #5020144
02/22/19 01:29 PM
02/22/19 01:29 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I grabbed 2 of the 30w. That should hold me for quite a while.
Re: Air Compressor Oil [Re: Michael_P] #5027598
03/01/19 12:08 PM
03/01/19 12:08 PM
Perris, CA
Anduril Offline
Anduril  Offline
Perris, CA
I use Mobil 1 AFE 0w-20 in mine. Makes a huge difference as to whether or not the motor actually starts and runs at the end of a long extension cord. Using generic "compressor oil," the motor would just hum and trip the breaker in colder weather after about 100' of cord or so.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Air Compressor Oil [Re: Michael_P] #5027797
03/01/19 02:28 PM
03/01/19 02:28 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I noticed on my compressor, that going to Amsoil compressor oil was a welcome change. I could fairly easily feel less heating on the head for my uses, though no calibrated result.
I would somewhat doubt that it would be filling easier, but I can see that the heavier oil might help with a tighter seal inside, plus reduced friction might allow marginally faster RPMs.
I’d personally change it after some use (a shorter oci), but unless you can reuse it somewhere for something, I’d run it for at least a little while to recoup some utility cost.
Re: Air Compressor Oil [Re: Michael_P] #5028245
03/01/19 08:42 PM
03/01/19 08:42 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Detergent (motor) oil in humid environments can foam and gum up the valves. Many get away with it, some don't. I stick to non-detergent compressor oil in mine.
For continuous use in a heated garage, I would upgrade to 30W synthetic anyway.
Various musings: http://hangfire.net
Re: Air Compressor Oil [Re: Anduril] #5028483
03/01/19 11:58 PM
03/01/19 11:58 PM
CA
user52165 Offline
user52165  Offline
CA
Use 100 ft of air hose, not 100 ft of electrical line.
