UOA done on my Volkswagen Amarok 2.0 TDI. This is the fourth yearly analysis - always done before service. Things were ok for the previous three.
Now, however, things have gone horribly wrong in my opinion.
Diagnosis from wearcheck:
Cylinder/liner wear rates are high. Piston and ring wear rates are higher than normal. Check that blow-by is not excessive. No fuel dilution evident. Higher than normal silicon (dust) level in the oil - check air intake system for leaks and for defective oil filler cap, breather or dipstick and dipstick holder. Dust entry made the oil unfit for further use. Oil already changed do not drain again. Please return feedback.
Some background - about 2000km ago I saw smoke coming from engine compartment one morning, and found that the crankcase breather pipe was not properly clipped on to tappet cover. This can then suck in unfiltered air after the filter into the engine :-( Vehicle was at dealer shortly before that, but they said they did not work in that area.
Code
1 2 3 4
Miles in service: 7616 7400 8680 5740
Vehicle mileage: 27000 34300 43000 48800
Iron normalized
per 1000km (621 miles): 5ppm 5.5ppm 6ppm 29.5ppm
The question is - how much permanent damage will the dust have done, and will it get better with clean oil now?
Code
1 2 3 4
Iron normalized
