I just picked up an F53 based class A and it had a tiny (Penz PZ 173) oil filter on it. I was on the road between Grand Rapids and Northern Ca (doing an oil change in the Napa parking lot in Sidney Ne), it was late afternoon, around 8 above zero, and I didn't feel like experimenting, so I put on a Napa 7045 which crossed with the PZ173, although they of course showed the correct filter to be the 1372. When I got home I put on a Napa gold 1372 and I feel better about it. But my question is, is there an even bigger (higher volume) filter that you can run on the 3v 6.8? Since I run these things fairly hard, it seems like a 7 qt capacity would be about 15% better than 6. The Difference may be irrelevant but Id still like to know if there is a bigger filter thats meets the spec. Ive never thought the 1372 was big enough for the 6.8, even though my interval is 3000 miles.
As an aside the crew at the Sidney Napa is great - very helpful and pleasant to work with!
