Sorry, I totally missed the laptop detail.
Buy once, cry once. If you plan to keep the laptop for a while, buy the SSD. While it may cost more today, I believe you get the most performance boost for the buck which may lead you to keep the laptop longer.
And if it doesn't work out with the laptop, you have a big SSD for the desktop....
Originally Posted by demarpaint
Originally Posted by javacontour
I thought I read a test that showed you really don't get that much of a boost.
This is one specific drive, but it's a relatively high performance HDD, and the difference isn't all that much.
https://benchspotter.com/content/seagate-firecuda-vs-wd-black-hard-drive-performance-review
I think one is better off using an SSD and if you need more space but it doesn't need to be as fast, use a traditional HDD for storage where speed isn't a primary concern.
I run a 512GB SSD as my boot and application drive and 7TB of spinning storage in my workstation at home.
My two towers and 17" laptop are set up that way, the OS and programs are on the SSD and data is on HDDs. The laptop in question here only has one slot for a hard drive, so I'd like a lot of cheap room the data.
