Originally Posted by 14Accent
I don't see anything about programming on that year Toyota, unless it has an immobilizer which yours does not. Have you verified power and ground to the ECM? What symptoms are there besides "it doesn't start". Do you have fuel pressure? Fuel injector pulse? Spark from the coils?
How did the original ECU get water damage? On a Tundra the ECM is high up under the dashboard, pretty darn protected from any water damage.
Thanks for the inputs, a locksmith came and said there is no immobilizer, it has been using a metal key (no chip). Everything you describe works EXCEPT no spark. This truck has been sitting with a broken front windshield, so water leaks into the dash (glove box) .... Thanks again
