Code
Fluid Manufacture Castrol
Fluid Category GTX Magnatec
Fluid Grade 5W20
Time on Unit 71952
Compartment Age 71952
Time on Fluid 7774
Metals (ppm)
Aluminium (Al) 6
Nickel (Ni) 1
Chromium (Cr) 2
Iron (Fe) 47
Copper (Cu) 33
Lead (Pb)
Tin (Sn)
Titanium (Ti)
Vanadium (V)
Silver (Ag)
Additives (ppm)
Potassium (K) 5
Molybdenum (Mo) 13
Boron (B) 18
Magnesium (Mg) 95
Calcium (Ca) 1790
Zinc (Zn) 702
Phosphorus (P) 575
Barium (Ba)
Contaminants (ppm)
Silicon (Si) 19
Sodium (Na) 7
Contaminants
Water (%)
Coolant No
Physical Tests
Viscosity (cSt 100C) 8.8
Physical / Chemical
Base Number (mgKOH/g) 2.2
This sample saw frequent towing, average mpg for the interval was 12.9. olm was at 1%. The filter used was a fram TG10575.
Comments from the lab: "Engine wear levels appear satisfactory for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Viscosity within specified operating range. Action: As oil and filter(s) already changed, resample next service interval to monitor and establish wear trend."
Fluid Grade 5W20
Time on Unit 71952
Time on Fluid 7774
Metals (ppm)
Aluminium (Al) 6
Nickel (Ni) 1
Chromium (Cr) 2
Iron (Fe) 47
Copper (Cu) 33
Lead (Pb)
Tin (Sn)
Titanium (Ti)
Vanadium (V)
Silver (Ag)
Additives (ppm)
Potassium (K) 5
Molybdenum (Mo) 13
Boron (B) 18
Magnesium (Mg) 95
Calcium (Ca) 1790
Zinc (Zn) 702
Phosphorus (P) 575
Barium (Ba)
Contaminants (ppm)
Silicon (Si) 19
Sodium (Na) 7
Contaminants
Water (%)
Coolant No
Physical Tests
Physical / Chemical
