seat belt retracts slowly
by NH73 - 05/28/20 05:19 AM
Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
52 registered members (AZjeff, Amkeer, 2K2AcuraTL, Astro14, Boxnuts, BlakeB, 6 invisible), 1,226 guests, and 57 spiders.
Topics305,960
Posts5,283,682
Members71,546
Page 2 of 2 1 2
Re: My WVO setup on plain stock engine [Re: Popsy] #5016364 02/19/19 12:36 PM
Superflan Offline OP
Originally Posted by Popsy
Mmm, that's weird. Small leak on the fuel "chain" letting a bit of air in?
Hi, just following up:
Indeed the suction side of the fuel system wasn't completely air tight, I discovered small leaks on junctions. Temporary repairs stopped the jerking
‘01 Peugeot Partner 1.9 D, 15W40 E7, 276000 Km, running straight WVO
Wife's '19 Suzuki Vitara 1.0 Boosterjet (TGDI), 5W40 A3/B4, 31000 Km
Backup ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 170000 Km
Re: My WVO setup on plain stock engine [Re: bullwinkle] #5302945 12/24/19 05:52 AM
discountdon Offline
Originally Posted by bullwinkle
I just hope it doesn't jam up your rings with glycerine, that seems to happen to all the Mercedes diesels that ran unconverted (into biodiesel) WVO.
can't you put some additive in the wvo or into your crankcase to prevent or dissolve that?
drain and filter that gelled used motor oil into 'black diesel' by mixing with a percentage of gasoline!
tongue2
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: My WVO setup on plain stock engine [Re: Superflan] #5384329 03/24/20 07:50 AM
Hi, I'd like to give BITOG a little update on my WVO car.
I'm now at 276000 kilometers, and I've found the sweetest blend I'm running for a few tanks now :
87,59% WVO (used Risso Amphora Elite, which when virgin is a blend of palm oil, sunflower oil with high concentration of oleic acid, colza oil, canola oil w/ high oleic acid, and E900 antifoam)
12,17% Ethanol free, Unleaded low-sulfur Gasoline
0,24% Stanadyne Performance Formula
The Stanadyne helps from running right even on cold start up. I just need to floor it an crank for less 10 seconds (if the fuel system didn't drain) and it runs like a charm.
I plugged a bunch of fuel filters lately, supposedly from a bad oil batch (mixed the filtered and raw jugs when cleaning garden). It seems to be still processing crap from the tank, as I'm now changing a fuel filter every 2 months.
Well, given all the experiments I did with that fuel system, you can guess that pretty much all the seals are going crap. Most of them are 20 years old, I make drops on the floor when rolling, when I start in the morning I have to crank a lot to prime everything. I'm looking to change them all. Starting with the Bosch VE pump... and then the feed & return lines, up to the tank.
Do you have any advices regarding fuel lines and filter ? For simplicity I would keep stock, but the fittings here and there aren't twice the same, so maybe I should just keep the fuel filter box (that includes the push primer and the heat exchanger) and customise everything else (including filters before the OEM one) ?
Re: My WVO setup on plain stock engine [Re: Superflan] #5385268 03/25/20 09:58 AM
Cujet Offline
Just off the top of my head, there are some very large diesel fuel filters that may allow you to run for an extended period of time without changing the filter so often. But it's always better to "refine" your fuel prior to dumping it into the fuel tank. I have a 0.5 micron "motorguard" air filter that works wonderfully with fuel. It can be converted to use a TP roll, so can be really cost effective. I've used it in a siphon to filter WMO for my Diesel Rabbit. Worked very well.
Page 2 of 2 1 2
