The premix is more expensive, but there is nothing otherwise wrong with it. I don't hate the 50/50 stuff as much as most people here do.
Originally Posted by Linctex
Originally Posted by das_peikko
DEXCOOL at Wal-Mart
Premix $12.44
Concentrate $14.47
Concentrate makes more economical sense.
CORRECT.... why anone would spend $5/gallon of water is beyond me, unless it is an emergency.
Have we (society) really become THAT darned lazy?
It's actually $10/gallon for that water!
$7 or so for the half gallon of concentrate coolant plus $5 for a half gallon of water
Originally Posted by Sayjac
Quote
…..Concentrate makes more economical sense.
Without a doubt. Premix is a nice racket for the AF companies though. It's also the predominate type sold as Asian AF, hard to find as a concentrate.
'If possible', concentrate plus distilled is the way to go.
Pep Boys has Asian coolant concentrate for about $20 a gallon. Recochem OEM brand. And when it's on sale, it's even less. I've seen it as low as $14/gal for the same Recochem concentrate
Originally Posted by vssjim
GM has always said DRINKABLE water which I assume means low in minerals or salts and acids is basically ok to mix and use for the life of coolant for anti corrosion
GM also pushes Dexcool/Deathcool
Use distilled, deionized, or the 50/50 premix
