Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
90 registered members (2015_PSD, 928, 97tbird, 55Test, 555, 55hambone, 15 invisible), 1,472 guests, and 30 spiders.
Topics307,431
Posts5,310,875
Members71,843
Red Line 0w-30 VOA #5015428 02/18/19 04:20 PM
N
NYSteve Offline OP
N
Submitted a VOA of Red Line 0w-30 using NAPA's kit, which seems to use ALS Labs for the actual analysis. The report say 10w-30 but was indeed 0w-30 purchased in Jan 2018.
Adding link to the UOA of the same oil:
https://www.bobistheoilguy.com/foru...-line-0w-30-9-478-miles-2008-lexus-gx470
Re: Red Line 0w-30 VOA [Re: NYSteve] #5015431 02/18/19 04:24 PM
PimTac Offline
Interesting. The silicon which is a anti-foaming agent seems quite high.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Red Line 0w-30 VOA [Re: NYSteve] #5015432 02/18/19 04:25 PM
Direct_Rejection Offline
Thanks for the VOA !
Would you like a little motor oil with your calcium ?
2019 Lexus UX 250h F-Sport
HPL HD 0W16 SL
@ 61k miles
Re: Red Line 0w-30 VOA [Re: NYSteve] #5015435 02/18/19 04:31 PM
B
buster Offline
B
RL's certainly consistent as they've barely changed anything over the years. This is clearly not the SN street oil. Thanks for sharing.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Red Line 0w-30 VOA [Re: NYSteve] #5015451 02/18/19 04:43 PM
N
NYSteve Offline OP
N
Glad I could contribute here! Added UOA link to the original post as well.
Re: Red Line 0w-30 VOA [Re: NYSteve] #5015457 02/18/19 04:47 PM
B
BobsArmory Offline
B
I wonder how this oil would work with cars that have LSPI issues.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
2007 Pontiac Grand Prix 3800 Series III
Re: Red Line 0w-30 VOA [Re: BobsArmory] #5015647 02/18/19 07:52 PM
stanlee Offline
This is really being over complicated. All that's been found are oils with high calcium levels have been correlated with LSPI. All oil manufacturers have done to address it is lower calcium. NO high calcium oil is going to be a good choice IF LSPI is an issue in your particular make (which it shouldn't be. Stop trying to make 2.0Ls feel like 5.0L V8s with these tiny hot running turbos and high low rpm loads. That's turbo 101 in the aftermarket turbo upgrade world for longevity). I've had two german DI turbo cars and this was never an issue on either despite the factory undersized turbos and overloaded low rpm range.
Re: Red Line 0w-30 VOA [Re: stanlee] #5015678 02/18/19 08:32 PM
G
Garak Offline
G
ZDDP and moly help with LSPI. Now, does Red Line's dosing counteract sufficiently for this?
Plain, simple Garak.
Re: Red Line 0w-30 VOA [Re: NYSteve] #5015897 02/19/19 12:53 AM
G
Gubkin Offline
G
This one https://www.redlineoil.com/0w30-motor-oil ?
A5/B5 and 229.5
HTHS 3.2
KV100 by PDS 69, by VOA 59
[censored]
Re: Red Line 0w-30 VOA [Re: Gubkin] #5016076 02/19/19 09:02 AM
N
NYSteve Offline OP
N
A5/B5 and 229.5
HTHS 3.2
[censored]
Correct
Re: Red Line 0w-30 VOA [Re: PimTac] #5016399 02/19/19 01:01 PM
MolaKule Offline
Global Moderator
Global Moderator
And this been my observation as well. Unless they are using some silicon-based compound other than, or in addition to, dimethylsiloxane, this seems excessively high.
This is definitely not a daily driver oil. Use it on track day only.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: Red Line 0w-30 VOA [Re: MolaKule] #5016423 02/19/19 01:25 PM
U
UG_Passat Online Content
Online Content
U
That silicon value is consistent with their other "High Performance" oils. Redline sells a separate line for track day Race oils.
2016 VW Tiguan
Re: Red Line 0w-30 VOA [Re: NYSteve] #5016462 02/19/19 01:54 PM
Marco620 Offline
Many thanks for doing this. I voa'd 0w20 but considering using this after I get to 400,000 miles.
15' Civic r18, 342,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: Red Line 0w-30 VOA [Re: Garak] #5016691 02/19/19 05:24 PM
dailydriver Offline
It would be cool if they started up a line of lower calcium/higher magnesium 'LSPI preventative' oils, while keeping their other additives at current levels. cool
But they obviously do not want to compete with the majors for modern engine oils (nor even the higher volume 'boutiques' for that matter). frown
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Red Line 0w-30 VOA [Re: NYSteve] #5085448 04/25/19 01:15 AM
Z
ZZman Online Content
Online Content
Z
Very strong package
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
