Originally Posted by antonmnster
Just went through this on a 14 Focus. It was horrible! At first, anyway,
I used a MAP torch for a couple of minutes. Then shot lots of penetrant around the flange and into the lug holes. Spin it around, rinse, repeat.
When using the big hammer, strike the hat on the edge. It's counter intuitive to hit it in, not out. MUCH more effective than hitting the swept area and not likely to break the disc.
Heat. WD-40. Hit smarter, not harder. By the time I got to number 4 it was off in 10 minutes.
Thanks. When you say hit the hat on the edge, do you mean hit it on the edge of the flat face where the studs are, or on the side of the step?
