Code
Make/Model Kia 1.6L GDI
Oil Type&Grade Napa Synthetic 5w-30 (Dexos1 Generation 2)
MI/HR on Oil 7,449
MI/HR on Unit 89,925
Sample Date 2/2/2019
Make Up Oil Add 0 qt
Element in PPM NS5w30 VS5w20 Universal Avg
7,449 7,428
Aluminum 6 5 4
Chromium 0 1 0
Iron 18 24 17
Copper 1 1 7
Lead 1 0 0
Tin 0 0 0
Molybdenum 63 54 59
Nickel 0 0 0
Manganese 0 0 1
Silver 0 0 0
Titanium 32 28 11
Potassium 1 2 1
Boron 52 47 36
Silicon 19 21 15
Sodium 10 95 78
Calcium 1111 1229 1841
Magnesium 803 663 170
Phosphorous 689 674 664
Zinc 779 728 747
Barium 1 0 1
Properties Sample Should Be
SUS Viscosity @210°F 55.5 53.1 54-63
cSt Viscosity @100°C 8.92 8.21 8.5-11.3
Flashpoint in °F *355* *370* >375
Fuel % 1.0 0.8
Antifreeze % 0.0 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.2 0.4
TBN - 2.2 >1.0
Comments:
The Kia looks good at 89,925 miles. The factory warranty might be almost over, but this engine is showing no signs of slowing down. 7,500-mile oil change intervals are working just fine. Universal averages are based on around 5,800 miles on the oil and you're getting average wear metals after a longer than average run. No complaints about that. Low insolubles and silicon indicate excellent oil and air filtration. The viscosity is at the thin end of the 5W/30 range, but neither that, nor fuel at 1.0% is harmful. Just keep up the good maintenance
MI/HR on Oil 7,449
7,449 7,428
Aluminum 6 5 4
Chromium 0 1 0
Iron 18 24 17
Copper 1 1 7
Lead 1 0 0
Tin 0 0 0
Molybdenum 63 54 59
Nickel 0 0 0
Manganese 0 0 1
Silver 0 0 0
Titanium 32 28 11
Potassium 1 2 1
Boron 52 47 36
Silicon 19 21 15
Sodium 10 95 78
Zinc 779 728 747
Barium 1 0 1
Fuel % 1.0 0.8
Water % 0.0 0.0
TBN - 2.2 >1.0
Comments:
