soo this is very odd, 2 days ago i took the battery out of the car (7th gen year 2000 toyota celica) to put a 2nd power cable through to the back of the car. not the first time iv done this since few months ago i put in a power cable for the amplifier through the same rubber bung.
this time when i put the battery back in the abs light was on as soon as the car was started. i did the obd2 pin jumper trick and got a abs code 32 which says front left sensor.
seeing how i used the car in the morning to go to the shops and back and no abs light was on until i put the power cable through i took the battery out again and inspected the area where i put my cable though (in the pic attached the blue one is the new one i put in 10awg size, the black cable covered in protective sleeve on the left i put in a few months ago 8awg) nothing seems to be a miss and damaged.
is this just a coincidence that removing the battery reset something and the sensor was already broken? i just cant believe the sensor has died but again i cant see any way my wiring could cause this problem?
just to add i did try resetting the code pressing the pedal 8 times but the light doesnt go out. not sure if that means its lost complete signal to the sensor.
