1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
77 registered members (ArrestMeRedZ, ARB1977, amblerman, 4WD, 94astro, 40w8, 3 invisible), 1,429 guests, and 71 spiders.
Topics306,081
Posts5,287,038
Members71,596
coolster 150 cc atv 2019 new #5013566 02/16/19 11:37 PM
H
hyperscion Offline OP
H
getting ready for its first oil change brand new. should i use syn 10w 40/?
or conv oil?
what is the weight of rear gear oil also syn vs conv?
the user manual is a joke.
any hlep is appreciated
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5013696 02/17/19 08:25 AM
skyactiv Offline
You don't need synthetic in it. if there is any soft, junk, cheap metals in the mechanicals, synthetic oil wont
make up for it. Usually those Chinese preteen sized ATV's fall apart and don't hold up.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5013724 02/17/19 09:19 AM
A
Audios Offline
A
Whatevers cheap or lying around will work fine.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5013765 02/17/19 10:01 AM
sw99 Offline
I ran T5 10w30 in mine and it worked great.
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5013894 02/17/19 11:50 AM
Srt20 Offline
I actually have 2 of the Chinese 110cc atvs for my kids. They have been very durable actually. Though I do go through them alot, tighten nuts and bolts, etc.
I forget what I used for oil, but Im fairly certain it was whatever I had laying around that wasnt expensive. probably 10w-30 or 40, conventional Valvoline or Supertech.
Mine are chain driven, no rear gear.
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5013917 02/17/19 12:10 PM
B
bubbatime Offline
B
Valvoline ATV 10W40 oil is available at Walmart for $4.xx a quart. Good stuff, cheap. More than enough.
Re: coolster 150 cc atv 2019 new [Re: sw99] #5029758 03/03/19 01:57 AM
H
H
i have 75w-90 gear oil,,,royal purple.
will this work for the cvt?
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5029760 03/03/19 02:00 AM
F
FordBroncoVWJeta Online Content
Online Content
F
NO. 75w-90 is WAY to thick for a CVT.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5040037 03/12/19 01:33 AM
J
JTK Offline
J
The 150cc is a fan cooled engine correct? Provided you don't use it in extreme heat, any 10w30 would be good, 15w40 better.
This unit has a separate gearbox I presume? The kid sized 110cc (not fan cooled) I had for my kids was single speed gas and go wet clutch that shared the engine oil sump. Like said, they're not bad machines for yard and light trail use for what they cost new or used. They won't hold up to major mudding, jumping, etc. You do have to go through every fastener with something like blue Loctite and neaten up the wiring if you want longevity out of them.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: coolster 150 cc atv 2019 new [Re: skyactiv] #5197828 08/27/19 09:54 AM
J
JDJ Offline
J
Not the engines... they've been copying/cloning Honda engines for so many decades they/re rock solid (provided you keep the fluids full and clean). In fact, for many smaller engines, Honda had them manufactured in China, so when Honda ended production, like with the GY6 style engine, it was simple for China to just keep on making them and putting them in their own vehicles.
The big thing with the China quads and bikes is to tighten every bolt after every ride the first few times, blue loctite and then you are generally OK. You replace items that break with upgraded parts as they fail, and after a while, you've got a solid machine. Usually they cheap out on things like t he plastics, seats and cushioning, and the shocks are usually overly stiff.
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5198096 08/27/19 02:55 PM
sw99 Offline
T4 Rotella 15w40 is all you need and it's pretty inexpensive also. I ran it in several TaoTao machines with good results.
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5209782 09/11/19 05:37 AM
R
Rob_Roy Offline
R
The 110cc Tao Tao we bought a few years ago came with a sticker on the engine recommending 15w-40. So far so good with the engine, but I have had to tighten a lot of fasteners on the rest of the machine.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: coolster 150 cc atv 2019 new [Re: Rob_Roy] #5212435 09/14/19 12:13 PM
J
JTK Offline
J
They've changed that recommendation then. When I mail-ordered the little TaoTao 4-wheeler for my kids back in 2008, they gave the standard 10w30 recommendation. I swapped it to inexpensive 15w40 after some run time.
The OP never really posted back, but his fan cooled 150cc and transmission is a very different setup than the 110cc's, but even that engine would benefit from 15w40 IMO.
Re: coolster 150 cc atv 2019 new [Re: hyperscion] #5213905 09/15/19 11:27 PM
Z
zrxkawboy Offline
Z
My son recently got a Taotao 110 dirt bike. The dealer recommended a first oil change after 3 tanks of gas. I changed it after 1 tank, and the oil had lots of glitter in it. I used Supertech 15W40.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: coolster 150 cc atv 2019 new [Re: JTK] #5234606 10/09/19 08:12 AM
J
JDJ Offline
J
The Coolster 150 is not anything special in terms of cooling compared to the 110s. It may (or may not) have a small fan to direct air onto the engine, but it is still air-cooled, not liquid... and the oversized computer case fan they would put on it is nearly useless. The OP's quad is very much like my generic Chinese 150 which is a GY6 engine. Other than being larger and using CVT instead of an integrated gearbox, it's not significantly different with regards to oil needs than my son's 110cc Chinese atv.
Either which way, doesn't matter... 10w40 or 15w40 for both engines is a great choice.
