2010 Jeep Wrangler 3.8 V6
No Make-up oil
52,000 on unit
5,000 on oil
Castrol Edge Bio-Synthetic 5w-30
Baldwin BT223 Filter
This is a nice report for your Wrangler. Metals are mostly steady compared to last time. The
engine did put a little more copper in the mix, but certainly not a problem level. We expect some variation
from sample to sample, just from normal variation in day-to-day use. The viscosity read in the 5W/20 range,
but it's been that way before and doesn't look like a problem now. The oil wasn't thinned by fuel and no
other contaminants showed up either. Oil filtration and combustion look great based on the low in-solubles.
This Jeep is doing fine at 52,000 total miles.
Aluminum 4
Chromium 1
Iron 8
Copper 21
Lead 0
Tin 0
Molybdenum 87
Nickel 0
Manganese 1
Silver 0
Titanium 9
Potassium 0
Boron 26
Silicon 12
Sodium 6
Calcium 1032
Magnesium 1150
Phosphorous 643
Zinc 863
Barium 0
SUS Viscosity @ 210F 49.1
CST Viscosity @100C 6.98
Flashpoint in F 420
Fuel % span>
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.1
In- Fleetguard LF3339 (Oversized Filter)
Pennzoil Platinum 0w-20- in Winter, single digits, doesn't sound so great at start-up.
Purchased new in 7/2010- No problems with this engine, runs smooth and quiet, burns no oil, even up to 7k.
No Make-up oil
52,000 on unit
5,000 on oil
Aluminum 4
Chromium 1
Iron 8
Copper 21
Lead 0
Tin 0
Molybdenum 87
Nickel 0
Manganese 1
Silver 0
Titanium 9
Potassium 0
Boron 26
Silicon 12
Sodium 6
Calcium 1032
Magnesium 1150
Phosphorous 643
Zinc 863
Barium 0
Flashpoint in F 420
Fuel % span>
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.1
