Originally Posted by HangFire
Originally Posted by Char Baby
Both meeting the same spec and boiling/wet boiling point with DOT3 & DOT4 having their own boiling point specs. And while I'm not sure, I think that DOT 4 has higher boiling point(s) but, may in fact absorb moisture more quickly.
Dot 4 does have a higher boiling point if not water saturated, but what I've heard is the old formulation is no longer used, so new DOT4 (or DOT3/4) lasts as long as DOT 3.
It's more convoluted than even that. Certainly the DOT 4 standard specifies a higher minimum dry boiling point than the DOT 3 standard, but it's certainly possible for a DOT 3 fluid to have a much higher dry boiling point that drops quickly when it gets wet. I understand some weekend racers use those by changing the fluid before a race day. I've seen "super heavy duty" DOT 3 fluid that claimed to have anywhere from a 450ºF to 500ºF dry boiling point. Here's one:
Quote
https://penray.com/products/super-heavy-duty-dot-3-brake-fluid/
• Dry boiling point exceeds 450ºF
• Wet boiling point 284ºF minimum
Here's the standards in the Code of Federal Regulations:
Quote
https://www.govinfo.gov/content/pkg/CFR-2011-title49-vol6/pdf/CFR-2011-title49-vol6-sec571-116.pdf
S5.1 Brake fluid. When tested in accordance with S6, brake fluids shall meet the following requirements:
S5.1.1 Equilibrium reflux boiling point (ERBP). When brake fluid is tested according to S6.1, the ERBP shall not be less than the following value for the grade indicated:
(a) DOT 3: 205 °C. (401 °F.).
(b) DOT 4: 230 °C. (446 °F.).
(c) DOT 5: 260 °C. (500 °F.).
S5.1.2 Wet ERBP. When brake fluid
is tested according to S6.2, the wet ERBP shall not be less than the following value for the grade indicated:
(a) DOT 3: 140 °C. (284 °F.).
(b) DOT 4: 155 °C. (311 °F.).
(c) DOT 5: 1 180 °C. (356 °F.).
S5.1.3. Kinematic viscosities. When brake fluid is tested according to S6.3, the kinematic viscosities in square millimeters per second at stated temperatures shall be neither less than 1.5 mm2/s at 100 °C. (212 °F.) nor more than the following maximum value for the grade indicated:
(a) DOT 3: 1,500 mm2/s at minus 40 °C. (minus 40 °F.).
(b) DOT 4: 1,800 mm2/s at minus 40 °C. (minus 40 °F.).
(c) DOT 5: 900 mm2/s at minus 40 °C. (minus 40 °F.).
S5.1.4 pH value. When brake fluid, except DOT 5 SBBF, is tested according to S6.4, the pH value shall not be less than 7.0 nor more than 11.5.
It's also convoluted with its lack of mention of DOT 5.1 other than it's a "non-silicone base" and has to be colorless to amber, while silicone must be colored purple. I suppose the assumption made is that DOT 5.1 simply must meet DOT 5 performance standards with a non-silicone base.
BTW - wasn't there some blue Pentosin DOT 4 brake fluid? I recall hearing that some would use that an alternate the blue with the amber version to determine when the previous fluid had been completely flushed out.
