2008 Suburban 1500 with the 5.3L AFM flex fuel engine. Just under 130K. Used mostly for commuting in-town at about 35 mph, 10 miles each way. Some summer towing up some pretty hefty mountain inclines, pulling a 4250 lb. trailer and gear.
I've been kicking around the idea of shutting off the AFM. I don't mind the idea of it, but as the components wear, their chances of failing obviously increase. It seems like a fairly complex system and I know the failed lifter fix isn't cheap. That said, the system is functioning flawlessly and the truck uses virtually no oil.
I initially looked at just shutting down the AFM with one of the Range devices. Their simplicity is great. Now, I'm wondering if a custom tune via a place like Black Bear makes more sense. My goal would be to maintain as many MPGs as I can, maintain towing performance, and prevent the AFM-related failures I read about. Perhaps that can be done via a tune.
I plan on keeping the vehicle for years. I've maintained it, hopefully, to go 200K. The difference in cost between a tune and the Range device won't be much of a factor.
Any advice one way or another? My mind is wide open on this right now.
