Originally Posted by hallstevenson
Originally Posted by y_p_w
I don't think they would do that, if only because many customers would complain about the price. I'm pretty sure most Honda dealer service departments still stock 5W-20 since it was still the standard until a few years ago.
I forgot that 0W-20 is only available as a synthetic (at least I think so) so on the cost aspect, yeah, you might be right. Then again, the point of Honda back-spec'ing the oil was partly so that their dealers could stock/use fewer oils so they could make up the higher price of synthetic with bulk purchasing.
The way they've back spec'ed them is a little bit funky though. Frankly I don't see why any vehicle where 5W-20 is back spec'ed can't also have 0W-20 listed, but they don't do that. I even remember back when 5W-20 was a fairly new recommendation, some people were thinking of using Honda's special 0W-20 (for the hybrid Insight) because it was known to be a "synthetic oil" and because it had Honda's specific approvals that were needed for 5W-20 applications.
Still - they started with the XW-20 oils 18 years ago. Although I suppose there's discussion about the meaning of "synthetic", but the API SN Plus standard is pretty high and even most 5W-20s are robust. I even wonder if it would have made a difference with the notorious Toyota or Honda sludge monsters if API SN Plus were somehow transported back in time.
