I find it somewhat laughable that some folks remove factory piston cooling nozzles on sub 300hp engines with imagined caveats such as "high HP/output" or "track use" or "pro engine builders for important spots".
Funnily enough, 2000HP/3500 ft-lb sled pulling diesels still run cooling squirters. At 6000rpm with a 30gph oil pump, no less.
The most that happens is an upgrade from 25 year old brittle/cracked plastic nozzles to replacement billet nozzles, with a similar bore size.
