2018 VW Atlas 3.6 4 Motion Reliability?
by GZRider - 09/16/19 11:48 PM
Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
47 registered members (A_A_G, BlakeB, carlprop, burla, bdcardinal, 3 invisible), 1,232 guests, and 30 spiders.
Topics294,667
Posts5,064,163
Members69,303
Most Online3,532
Jul 30th, 2019
'18 Ford Flex, Mobli 1 5w-20 #5008269 02/11/19 07:35 PM
R
Redright9 Offline OP
R
Hello, I have a 2018 Ford Flex with the 3.5l V6. It has about 15,250 miles on it and I have changed the oil since new (three times) every 5k miles. I used Mobil 1 5w-20 and a Mobil 1filter as well. I am not sure why they put a 6800 mile change interval, I kept it at every 5k. Take a look at the report let me know what you think:
(image removed; personal data. see below)
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008276 02/11/19 07:45 PM
B
bullwinkle Offline
B
I think they compared your engine to a typical 3.5 with 6800 miles on an oil change. SIlicon is a little high, but that can still be break-in occurring, but it's always a good idea to make sure your air filter & plumbing isn't leaking. Think I would hide your personal info, myself, the internet can be a dangerous place!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: bullwinkle] #5008462 02/12/19 12:27 AM
R
R
Oh shoot! Totally slipped my mind! Thanks!
I think Im hosed.. cant figuee out how to get my personal info off. Thanks again, I feel dumb!
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008491 02/12/19 03:10 AM
T
The_Nuke Offline
T
Ask the mods to delete the image from your original post and replace it with the one attached to this post (or delete the original post and create another one with the attached image instead):
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008518 02/12/19 06:07 AM
dnewton3 Offline
Global Moderator
Global Moderator
The wear itself is OK and nothing alarming. Keep an eye on the Si and make sure it's coming down; if not, look for air leak in the intake tract.
There's no need to run a syn for 5k mile OCIs; that's a total waste of money. Any decent brand conventional oil will do just fine; these engines don't need anything special.
The 3.5L Duratec is a good engine, except for the placement of water-pump inside the timing cover. Keep an eye on the coolant bottle and the UOAs for coolant. That may or may not give indication of pump failure. If you're lucky, the pump will fail outwardly and leak out the weep hole near the alternator and let you know things are amiss. If you're not lucky, the shaft seal will fail and it will leak internally into the sump and contaminate the oil. Unfortunately, at times it happens so quickly that you'll not see it in the UOA because it can go bad in 100 miles, and you'll never sample often enough to catch the data shift. Other times it's a slow degradation and you'll see evidence of coolant in the oil. Some pumps have been known to last 150k miles or more; others have failed as early at 60k miles. No rhyme or reason to it. Some hate the engine for this, because a water-pump job can cost around $1500 on this engine. That is admittedly expensive, but it's mostly all labor.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008524 02/12/19 06:26 AM
Snagglefoot Offline
It probably wouldn’t hurt to step up your coolant changes to something more than the normal 5 years. How about 3 years? Also make sure to flush or dilute the old stuff out. I just did a post showing you have to fill and drain more than once with distilled water to get most of it out. smile
If you want the job done right......do it yourself.
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008590 02/12/19 08:43 AM
R
R
Thank you for removing my image and re posting it without my personal info, I'm still shaking my head I did that!! And I have heard about the water pumps on these engines, it makes me nervous, but I will keep an eye out for it.
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: dnewton3] #5008691 02/12/19 11:05 AM
Zee09 Offline
Steps were taken by Ford several years ago to make the pump more reliable.
"If I walked on water, they'd say I couldn't swim."
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008706 02/12/19 11:19 AM
K
KGMtech Offline
K
I think you are okay on the water pump for your Flex. They changed the drive design to a double sprocket from single sprocket, I suspect they upgraded the bearing within the pump. One would hope this would remove concerns....but you will have to monitor the 2 external weep holes for water pump that are part of this engine.
My 2009 Flex is at 200,000 km and is not yet leaking, but I plan to do the water pump pro-actively this Spring.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: '18 Ford Flex, Mobli 1 5w-20 [Re: Redright9] #5008786 02/12/19 12:21 PM
dnewton3 Offline
Global Moderator
Global Moderator
I was unaware of the water-pump upgrade re: the drive design. Surely would like to think they did something at least, specifically for the bearings and seals. Did they make a different chain drive to match the dual roller drive on the pump? Would like to learn all I can about this as I just got a new 2018 Taurus with the same engine, so I have skin in the game!
