Delo Syn-Gear 75w-90/140
CALIFORNIA
Looking at doing a gear oil change on my 1994 dodge ram with the Cummins. Front dana 60 and rear dana 70 with a limited slip. While I'd like to run redline, shaeffers, or amsoil, those are simply out of my price range. How does the Delo Syn-gear look? I've read the SDS (https://cglapps.chevron.com/sdspds/SDSDetailPage.aspx?docDataId=426535&docFormat=PDF) and can't tell if I still need to add friction modifier. Your thoughts and experience is welcome. Thank you.
Should work just fine without the addition of any friction modifiers, but it wouldn't hurt to check out one of the Cummins or Dodge p/u forums to verify that.
