Hey BusyLittleShop
by Shannow - 10/21/19 04:47 AM
TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
by SavagePatch - 10/21/19 12:53 AM
Milwaukee 2485-20 M12 1/4” Right Angle Die Grinder
by The Critic - 10/21/19 12:41 AM
Group 78 Battery Connector Issues
by Falcon_LS - 10/21/19 12:37 AM
Factors that can affect warming up time
by SlavaB - 10/20/19 11:59 PM
A nokian lineup review
by UG_Passat - 10/20/19 11:19 PM
Dealer Oil Change
by HowAboutThis - 10/20/19 10:35 PM
small qty of automitive paint
by danez_yoda - 10/20/19 09:36 PM
2017 Chevy Cruze recommended oil filter
by Electromotive - 10/20/19 09:13 PM
4L80E to Allison filter conversion
by P10crew - 10/20/19 09:03 PM
Pickles and gardenia
by 53' Stude - 10/20/19 09:00 PM
Weird Electrical Problems Due To Bad Ground.
by RayCJ - 10/20/19 08:59 PM
ECOGARD X 4610 CUT OPEN
by 53' Stude - 10/20/19 08:23 PM
FRAM ULTRA 7317 CUT OPEN
by 53' Stude - 10/20/19 08:17 PM
Easy to use free video editor
by Rat407 - 10/20/19 08:11 PM
Best budget tire for 2006 Nissan Pathfinder SE
by Dogred08 - 10/20/19 07:51 PM
Latest on SSD, HDD and USB Drives?
by JHZR2 - 10/20/19 07:43 PM
Oxy Clean On Leather Seats...WoW
by Warstud - 10/20/19 07:22 PM
Winter street biking
by CourierDriver - 10/20/19 06:47 PM
whizznbyu, Oildude, JDVW2019, Carlos40A, GeraldT
69624 Registered Users
37 registered members (AEHaas, 2015_PSD, Best F100, Bailes1992, bernau, 5 invisible), 743 guests, and 19 spiders.
Topics296,251
Posts5,094,224
Members69,624
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Is aluminum anti-seize compatible with copper. [Re: Linctex] #5008425 02/11/19 10:51 PM
M
MoreCowbellAz Offline OP
M
Originally Posted by Linctex
Originally Posted by MoreCowbellAz
I always assumed copper core plugs needed anti-seize while Iridium didn't, but maybe that's a bad assumption.
The copper (or none) located in the center electrode has absolutely nothing to do with the price of tea in China.
I guess what I meant was it appeared to me that there was a general tendency that the makers of iridium plugs also put on anti-corrosive plating while a lot of those less expensive copper core plugs didn’t have that plating, presumably to bring the cost down. I thought perhaps the reason behind that was because one is a more modern design and one was more old-school, not because there was something inherant that says iridium needed to be matched with plated threads. Two separate things I understand, i’ve just never seen an anti-seize come on a plug from the manufacture except on a copper core. All of the iridium plugs I’ve seen have that plating and they say specifically to not use anti-seize. But I am no plug expert, just my casual observation.
07 Toyota RAV4 2.4L
07 Toyota Prius Touring
00 Harley Road King Classic
11 Kia Soul 2.0L (mine to maintain)
Re: Is aluminum anti-seize compatible with copper. [Re: MoreCowbellAz] #5008620 02/12/19 09:30 AM
M
M
Well there you have it, according to Champion they don’t recommend using anti-seize Of any type, due to overuse in which case it messes up heat transfer as well as possibly contaminating the electrode. They go on to say if I do use some, use only a very small amount and start at least two threads up from the bottom. Even in that case, they don’t mention which type of anti-seize to use. So I guess to them any type or non at all.
As an aside On the champion website they have an article about removing difficult or stuck plugs, and even there they never mention using some type of anti-seize to avoid this in the future. They talk about using penetrants etc instead to loosen things up before removing.
07 Toyota RAV4 2.4L
Re: Is aluminum anti-seize compatible with copper. [Re: MoreCowbellAz] #5013237 02/16/19 03:53 PM
Snagglefoot Online Content
Online Content
Here is a photo of Permatex 133H Anti-seize. I have a lot of it left. I don’t think it's available any more but if you google it you’ll find it was a blend of aluminum, copper and graphite. In fact maybe that’s one you used? It looks like aluminum but actually has some copper in it, so I don’t think they are a problem to mix. Just my 2cents .
If you want the job done right......do it yourself.
Re: Is aluminum anti-seize compatible with copper. [Re: MoreCowbellAz] #5013648 02/17/19 03:03 AM
V
vw7674 Offline
V
Yes, that's the perp right ^ there. 133H with the graphite.
Must be the ingredient that makes it want to carbon track,
Like others mentioned, avoid the first few threads, tiny portion
per plug (less than a sharpened lead of a No.2 pencil,)
& I would try to apply every OTHER time but that would require a log book. lol.
Don't get cute & use engine oil either, that can turn to molasses or cement-like carbon too. Becomes scary-tight.
Page 2 of 2 1 2
