Hey BusyLittleShop
by Shannow - 10/21/19 04:47 AM
TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
by SavagePatch - 10/21/19 12:53 AM
Milwaukee 2485-20 M12 1/4” Right Angle Die Grinder
by The Critic - 10/21/19 12:41 AM
Group 78 Battery Connector Issues
by Falcon_LS - 10/21/19 12:37 AM
Factors that can affect warming up time
by SlavaB - 10/20/19 11:59 PM
A nokian lineup review
by UG_Passat - 10/20/19 11:19 PM
Dealer Oil Change
by HowAboutThis - 10/20/19 10:35 PM
small qty of automitive paint
by danez_yoda - 10/20/19 09:36 PM
2017 Chevy Cruze recommended oil filter
by Electromotive - 10/20/19 09:13 PM
4L80E to Allison filter conversion
by P10crew - 10/20/19 09:03 PM
Pickles and gardenia
by 53' Stude - 10/20/19 09:00 PM
Weird Electrical Problems Due To Bad Ground.
by RayCJ - 10/20/19 08:59 PM
ECOGARD X 4610 CUT OPEN
by 53' Stude - 10/20/19 08:23 PM
FRAM ULTRA 7317 CUT OPEN
by 53' Stude - 10/20/19 08:17 PM
Easy to use free video editor
by Rat407 - 10/20/19 08:11 PM
Best budget tire for 2006 Nissan Pathfinder SE
by Dogred08 - 10/20/19 07:51 PM
Latest on SSD, HDD and USB Drives?
by JHZR2 - 10/20/19 07:43 PM
Oxy Clean On Leather Seats...WoW
by Warstud - 10/20/19 07:22 PM
Winter street biking
by CourierDriver - 10/20/19 06:47 PM
whizznbyu, Oildude, JDVW2019, Carlos40A, GeraldT
69624 Registered Users
31 registered members (billt460, 1960Elco, cos, bbhero, bmod305, 3 invisible), 870 guests, and 21 spiders.
Topics296,251
Posts5,094,231
Members69,624
Most Online3,532
Jul 30th, 2019
Specs: Fram Extra Guard CA10344 #5008033 02/11/19 02:55 PM
B
Blurider24 Offline OP
B
Hey Folks,
I'm in information gathering "mode" and reached out to Fram for specs on their Extra Guard filter for my CR-V--the CA10344. Fram got back to me at 6:47 AM after I pinged them Sunday night.
The CA10344 was tested by ISO 5011, it tested at a flow rate of 127.2 CFM, Initial restriction rated 1.42 "H2O, accumulative efficiency of 99.45 %. It has a media surface area of 600 sq in. and a capacity of 200.4 grams.
Thanks for contacting Fram,
Of interest is the statement, "accumulative efficiency of 99.45%".
Does "accumulative" mean that it traps 99.45%...initially/new, or when it has a layer of cake/debris on it after accumulating some miles/dust?
2007 Honda CR-V EX AWD 165k miles
Quaker State UD Syn 5w-20 (7-8k OCI)
Fram Ultra Synthetic (Every other OC)
Valvoline MaxLife ATF (Every OC)
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008051 02/11/19 03:15 PM
StevieC Offline
Thanks. Good to know they are forthcoming with this information. thumbsup
'18 Caravan - 42k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008055 02/11/19 03:22 PM
K
kschachn Offline
K
Accumulative efficiency is the percentage of test dust that is captured vs. what was fed to the filter. Accumulative gain is how much weight the filter gains after test.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 284K
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008200 02/11/19 05:59 PM
B
B
That's pretty phenomenal, considering the Fine Test dust component of the ISO 5011 has 4.5-5.5% of the particles less than 0.97 Micrometers...if I'm reading this right.
ISO 12103.1, A2 Fine Test Dust
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008334 02/11/19 08:49 PM
L
Linctex Offline
L
Originally Posted by Blurider24
and a capacity of 200.4 grams.......?
That's far, FAR higher then what most manufacturers claim for capacity
Re: Specs: Fram Extra Guard CA10344 [Re: Linctex] #5008963 02/12/19 03:00 PM
B
B
Given that information, I wonder if mass would be a good indicator of when to change the filter. Well, intake vacuum seems to be a more appropriate measure, but for those that don't have a gauge, but have a scale.
200.4g is a lot--0.44Lb's?? I don't have a basis for comparison. But, when I look at it being spread out over 600 sq inches of filter media...which is a 4.167 sq feet, which gives you an area of ~2 feet x ~2 feet...that seems pretty insignificant.
Like I said though, I have no basis for comparison--can anyone share other information?
I sent requests out to AC Delco, Denso, Fram, Mahle, WIX on Sunday:
AC Delco: Encouraged me to f/u with their service centers for product info as they did not have that information
Denso: No answer yet.
Fram: As noted above.
Mahle: No answer yet.
Wix: No answer yet.
--Cheers!
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008971 02/12/19 03:04 PM
B
B
Cancel that, Wix answered moments ago, but haven't perused the PDF--will post a f/u.
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008992 02/12/19 03:20 PM
B
B
So, Wix gave me a less specific answer than Fram
Here is information on 49058
Product Specifications for part number 49058
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=1548973 [which is easily found and gives none of the information requested]
WIX Premium Panel Air Filters provide excellent engine protection for normal and severe driving conditions such as stop and go traffic, dirt roads, construction sites, short trips, and interstate travel. WIX filters are recommended for OEM air filter change intervals. These filters contain 30% more media than OES filters and use a phenolic resin treated enhanced cellulose media which provides excellent durability against moisture ingestion. When applicable, the high-tear strength polyurethane seal survives extreme hot and cold temperature conditions. Air filter Laboratory Tests per ISO 5011 at least 99.5% efficiency (Based on Wix 42389)
I looked up Part 42389, which is for a Dodge Caravan, Town & Country (01-10), Sebring, Avenger (07-10), VW Routan (09-10)
(shrugs) I don't think their response merits a new thread, honestly.
--Cheers!
--For the search engines:
2007 2008 2009 Honda CR-V CRV
