need brake job but ...
by Bluebonnet. 04/25/19 05:12 PM
UOA on BMW 0w-30 on BMW F10 M5 with S63 TVDI V8
by AirBull. 04/25/19 05:08 PM
What to drink with trail mix?
by das_peikko. 04/25/19 04:55 PM
And This Folks, Is How You Buy Guns
by billt460. 04/25/19 04:43 PM
Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
115 registered members (28oz, 53' Stude, 240_Ed, AirBull, ad_infinitum, 01rangerxl, 12 invisible), 2,136 guests, and 22 spiders.
Topics288,045
Posts4,939,805
Members67,902
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Well water instead of distilled water? #5008227
02/11/19 06:45 PM
02/11/19 06:45 PM
va
dx92beater Offline OP
va
My deep well water supply is loaded with filters and gadgets that I don't quite understand. I am assuming that it has at least a reverse osmosis system. I am working on identifying each part.
I already know that distilled water is cheap. I have been using it for years.
I just wanted to know if well water could ever contain as little of "x" as to be just as good as distilled water when mixing with coolant.
Just curious.
Thanks
Galant VR4, Talon TSI AWD, Forester XT, Caravan AWD, Focus, GMC Truck
Re: Well water instead of distilled water? [Re: dx92beater] #5008233
02/11/19 06:55 PM
02/11/19 06:55 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
Very unlikely. For a coolant you want either distilled or de mineralized water. Reverse osmosis will remove some minerals, but not all. When I was in Saudi Arabia our compound took the de salinated water from the tap and ran it through a reverse osmosis. That improved the water a lot, but it still had some salt in it.
2014 Passat Wolfsburg, 1995 Miata.
Re: Well water instead of distilled water? [Re: dx92beater] #5008244
02/11/19 07:08 PM
02/11/19 07:08 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
My reverse osmosis system pretty much takes everything out. I know what Redbone is talking about and he is right but a good home system does a better job. I used my reverse osmosis well water for the flushes and used store bought distilled water to mix with the coolant. Could have probably used the reverse osmosis for everything.
If you want the job done right......do it yourself.
Re: Well water instead of distilled water? [Re: dx92beater] #5008251
02/11/19 07:12 PM
02/11/19 07:12 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
RO water is fine for cooling systems. Total dissolved solids will be near nil. As will most forms of contaminates, including metals and tannins.
Re: Well water instead of distilled water? [Re: Cujet] #5008260
02/11/19 07:19 PM
02/11/19 07:19 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
For numbers
My tap water
Winter water (colder)
cold 280
hot 470
Summer water (tested last summer)
cold 350-420
hot 500-800
The RO water after emptying the tank is 6-10
RO water after being in tank for a few days usually around 26-30
Re: Well water instead of distilled water? [Re: dx92beater] #5008261
02/11/19 07:22 PM
02/11/19 07:22 PM
pa
benjy Online content
benjy  Online Content
pa
your body needs minerals + some RO systems are said to replace them some how, distilled water is similar you need to replace the minerals for your health. remember reading olympic athletes drink only distilled water + they are tested for all minerals in their body + replaced as needed. very costly + prolly paid by out tax $$$$ like most governmental things
Re: Well water instead of distilled water? [Re: redbone3] #5008272
02/11/19 07:36 PM
02/11/19 07:36 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
We have a cheap Reverse Osmosis systen @ work. It works well enough. Had it tested and we only have 3ppm of contaminants. The water going in has 200~ PPM.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Well water instead of distilled water? [Re: dx92beater] #5008284
02/11/19 07:54 PM
02/11/19 07:54 PM
Flyoverland, KY
Lou_Boyle Offline
Lou_Boyle  Offline
Flyoverland, KY
Other possible problems with well water are the dissolved gases. Some wells in certain areas can have high levels of dissolved CO2 which will create an acidic low pH condition. As a teenager we had well water and i was mystified why all our cars and machinery developed leaky radiators after 2-3 years even though the used cars we acquired werent leaking when we bought them. When i got to chemistry class in college i checked our drinking water found it had a pH of 5.5. If you do use well water boiling it vigorously before using it will strip out the dissolved gases.
The early bird may get the worm but it's the second mouse that gets the cheese.
Re: Well water instead of distilled water? [Re: Lou_Boyle] #5008294
02/11/19 08:05 PM
02/11/19 08:05 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
I boiled all the water at our compound that was used as potable water. Didn't trust the system, the people running the system, or the people responsible for the system.
Re: Well water instead of distilled water? [Re: dx92beater] #5008315
02/11/19 08:26 PM
02/11/19 08:26 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Or just buy pre-mixed coolant and forget about it.
HDEO in Diesel Engines. No spark plugs here.
Re: Well water instead of distilled water? [Re: PiperOne] #5008320
02/11/19 08:32 PM
02/11/19 08:32 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Naw, that's more money. For some reason, premixed 50/50 coolant is just about $1 or $2 cheaper than full strength. So you're paying almost double for what's basically a half gallon of distilled water.
Re: Well water instead of distilled water? [Re: dx92beater] #5008339
02/11/19 08:53 PM
02/11/19 08:53 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Distilled water at Walmart or Stop and Shop is $1 or so per gallon. Pretty affordable.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Well water instead of distilled water? [Re: dx92beater] #5008340
02/11/19 08:54 PM
02/11/19 08:54 PM
ME
eljefino Offline
eljefino  Offline
ME
If you have a softener I wouldn't run well water. Nor if you live somewhere that tastes like lime (Youngstown OH impressed this on me, notably).
Re: Well water instead of distilled water? [Re: dx92beater] #5008342
02/11/19 08:55 PM
02/11/19 08:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Probably:
1) An iron filter, followed by a
2) softener system, which feeds the
3) Reverse Osmosis system
Re: Well water instead of distilled water? [Re: Wolf359] #5008346
02/11/19 08:56 PM
02/11/19 08:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
EXACTLY!!! I don't understand how so many people don't "get" this concept
Page 1 of 3 1 2 3
