Originally Posted by JFAllen
Originally Posted by Tydaddy
I used the pennzoil previously in a 2010 touareg tdi. I'm just on the fence. Thinking the 0w30 would be better upon startup, however, no clue how the moly and additive package in the schaeffers would affect the ability to cling/flow/do whatever magical stuff it does at startup.
504/507 oils tend to not include much if any moly additives. As it's a 'low-ash' / mid-SAPS' oil the anti-wear additives must not produce ash if possible (MoDTC does not fall into this category.) For these reasons (and no doubt others) most 504/507 oils are
Boron heavy in their additive package. PP Euro LX0W30 is no different with +500ppm Boron.
Regards
Jordan
Thanks. Moly is schaeffers thing though.
"Advanced European Performance Mid SAPs SAE 5W-30 also contains two proven frictional
modifiers, Micron Moly®
, a liquid soluble molybdenum and Schaeffer Mfg.'s own proprietary
additive, Penetro. Once plated, these two proven frictional modifiers form a long lasting, slippery,
tenacious lubricant film, which prevents metal surfaces from coming into contact with each other
and helps prevent damaging frictional wear, reduce wear and provide:
ï¶ Increased fuel economy
ï¶ A low coefficient of friction
ï¶ Significantly less bearing, ring, piston, cylinder and valve-train wear
ï¶ Increased engine efficiency and engine durability
ï¶ Increased engine life, less down-time and reduced maintenance costs"
