Fat Wallet Forum
by LazyDog. 02/21/19 10:09 AM
Orange washer fluid?
by atikovi. 02/21/19 10:01 AM
Recommended laptop carrying case
by paulri. 02/21/19 09:47 AM
Collagen and Gelatin for protein supplement
by Lolvoguy. 02/21/19 09:36 AM
Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
120 registered members (Astro14, atikovi, ABCarr, aquariuscsm, 240_Ed, 14 invisible), 1,726 guests, and 52 spiders.
Topics284,604
Posts4,873,239
Members67,298
Most Online2,548
Feb 16th, 2019
Specs: Fram Extra Guard CA10344 #5008033
02/11/19 01:55 PM
02/11/19 01:55 PM
Roaming the US
Blurider24 Offline OP
Roaming the US
Hey Folks,
I'm in information gathering "mode" and reached out to Fram for specs on their Extra Guard filter for my CR-V--the CA10344. Fram got back to me at 6:47 AM after I pinged them Sunday night.
The CA10344 was tested by ISO 5011, it tested at a flow rate of 127.2 CFM, Initial restriction rated 1.42 "H2O, accumulative efficiency of 99.45 %. It has a media surface area of 600 sq in. and a capacity of 200.4 grams.
Thanks for contacting Fram,
Of interest is the statement, "accumulative efficiency of 99.45%".
Does "accumulative" mean that it traps 99.45%...initially/new, or when it has a layer of cake/debris on it after accumulating some miles/dust?
2007 Honda CR-V EX AWD 148k miles
Valvoline Syn HM 0w-20
Fram Ultra Synthetic
Honda DW1 to Valvoline SynHM--2 drain/fill @ 147,400 & 148,100
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008051
02/11/19 02:15 PM
02/11/19 02:15 PM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
Thanks. Good to know they are forthcoming with this information. thumbsup
'18 Dodge Grand Caravan GT - 21k KM - AMSOIL SS 0w30
'06 Hyundai Santa Fe - 535k KM (Dead) - AMSOIL SS 0w30
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008055
02/11/19 02:22 PM
02/11/19 02:22 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Accumulative efficiency is the percentage of test dust that is captured vs. what was fed to the filter. Accumulative gain is how much weight the filter gains after test.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008200
02/11/19 04:59 PM
02/11/19 04:59 PM
Roaming the US
Roaming the US
That's pretty phenomenal, considering the Fine Test dust component of the ISO 5011 has 4.5-5.5% of the particles less than 0.97 Micrometers...if I'm reading this right.
ISO 12103.1, A2 Fine Test Dust
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008334
02/11/19 07:49 PM
02/11/19 07:49 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by Blurider24
and a capacity of 200.4 grams.......?
That's far, FAR higher then what most manufacturers claim for capacity
Re: Specs: Fram Extra Guard CA10344 [Re: Linctex] #5008963
02/12/19 02:00 PM
02/12/19 02:00 PM
Roaming the US
Roaming the US
Given that information, I wonder if mass would be a good indicator of when to change the filter. Well, intake vacuum seems to be a more appropriate measure, but for those that don't have a gauge, but have a scale.
200.4g is a lot--0.44Lb's?? I don't have a basis for comparison. But, when I look at it being spread out over 600 sq inches of filter media...which is a 4.167 sq feet, which gives you an area of ~2 feet x ~2 feet...that seems pretty insignificant.
Like I said though, I have no basis for comparison--can anyone share other information?
I sent requests out to AC Delco, Denso, Fram, Mahle, WIX on Sunday:
AC Delco: Encouraged me to f/u with their service centers for product info as they did not have that information
Denso: No answer yet.
Fram: As noted above.
Mahle: No answer yet.
Wix: No answer yet.
--Cheers!
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008971
02/12/19 02:04 PM
02/12/19 02:04 PM
Roaming the US
Roaming the US
Cancel that, Wix answered moments ago, but haven't perused the PDF--will post a f/u.
Re: Specs: Fram Extra Guard CA10344 [Re: Blurider24] #5008992
02/12/19 02:20 PM
02/12/19 02:20 PM
Roaming the US
Roaming the US
So, Wix gave me a less specific answer than Fram
Here is information on 49058
Product Specifications for part number 49058
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=1548973 [which is easily found and gives none of the information requested]
WIX Premium Panel Air Filters provide excellent engine protection for normal and severe driving conditions such as stop and go traffic, dirt roads, construction sites, short trips, and interstate travel. WIX filters are recommended for OEM air filter change intervals. These filters contain 30% more media than OES filters and use a phenolic resin treated enhanced cellulose media which provides excellent durability against moisture ingestion. When applicable, the high-tear strength polyurethane seal survives extreme hot and cold temperature conditions. Air filter Laboratory Tests per ISO 5011 at least 99.5% efficiency (Based on Wix 42389)
I looked up Part 42389, which is for a Dodge Caravan, Town & Country (01-10), Sebring, Avenger (07-10), VW Routan (09-10)
(shrugs) I don't think their response merits a new thread, honestly.
--Cheers!
--For the search engines:
2007 2008 2009 Honda CR-V CRV
Moderated by  ekpolk
