Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
95 registered members (Al, alienyouth33, 2004tdigls, 1foxracing, Alfred_B, 13 invisible), 1,521 guests, and 51 spiders.
Topics284,600
Posts4,873,164
Members67,298
Most Online2,548
Feb 16th, 2019
Page 4 of 4 1 2 3 4
Re: How should I choose portable generator? [Re: Lenny5160] #4521959
09/21/17 07:03 AM
09/21/17 07:03 AM
Canada
boraticus Offline
boraticus  Offline
Canada
My EF2000is used approx. 2 oz (60 ml) of oil every 30 hours or so for the first 900 hours of operation.
As the hours accumulated, I noticed that sometimes, oil consumption would be minimal then on the next inspection, it would be back up.
Prior to accumulation of say, 700 hours or so, the oil consumption was consistently high by my standards. Once the engine got into the higher hours of use, it began to fall off and by the time it hit 900 hours, oil consumption had dropped significantly. It's now to the point that it may use only a little over 2 oz. in a 100 hour run, which is the oil change interval number.
I last did an oil change a couple days ago and the used oil (Shell Rotella blend 15/40-10W30 - 50-50) was only slightly darker than fresh oil. It's amazingly clean for used oil. I suspect that the used oil probably had plenty of service life left in it. However, at only .4 liter for a fresh fill, no need pushing it.
Re: How should I choose portable generator? [Re: Lenny5160] #4521974
09/21/17 07:20 AM
09/21/17 07:20 AM
Canada
boraticus Offline
boraticus  Offline
Canada
I suspect that despite multiple light load - heavy load break in procedures, the engine took much longer to actually break in under relatively light load continuous operation. My usual load is probably less than 500 watts with occasional heavy loading when operating things like a microwave oven or medium load power tools.
It would appear that due to the stubborn resistance to breaking in, the components are likely very durable. Which in turn would lead me to believe that this engine is designed and built for long service life.
My fears are that from reports I've read regarding Chinese versions of these generators, the above qualities may very well be compromised by Yamaha's choice to farm out the construction of these generators to China. I've yet to see anything positive from farming out Japanese manufacturing to China.
Re: How should I choose portable generator? [Re: linjiawen] #5006554
02/10/19 08:44 AM
02/10/19 08:44 AM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
To recommend a generator, the op needs to provide a lot more info.
That electric devices are you planning to run with the generator, both camping and at home?
Is noise a consideration?
Are we tent camping or rv camping with ac, microwave etc.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: How should I choose portable generator? [Re: linjiawen] #5007256
02/10/19 06:20 PM
02/10/19 06:20 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I am not sure a generator for camping will be the same as one for home emergency use. Two way different sets of electric loads.
As others have said you need to get a list of loads that will be powered by a generator. If motors then a starting and running load. Can you stagger starting loads? Like turn on refrig, then turn on freezer for example
2015 Ford F250 w/Powerstroke
Re: How should I choose portable generator? [Re: linjiawen] #5007789
02/11/19 09:57 AM
02/11/19 09:57 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
The Joplin tornado tore up a lot of infrastructure. There were lucky people that were just without electricity for a few days to a few weeks. A big gasoline generator will suck down 15 gallons a day. Gas was over $3.00 a gallon then, it was $45 a day for the big genny, Insurance does not cover that. If you have a way to stagger loads and can live with only a small window airconditoner in one room and then fans for the rest of the house a 3500 watt unit can get you by. Mine used just over 5 gallons a day.. I changed the oil every 2 days (50 hours) used Tropartic and never had a issue. Electric hot water heater is a no go unless you have the ability to wire it for 110V and it will let you. Then you have VERY limited hot water.
Rod
Page 4 of 4 1 2 3 4
Moderated by  ekpolk
