Took a ride in a 2018 Buick TourX
by Rumble. 04/20/19 06:45 PM
Solar panel with charge controller.
by spasm3. 04/20/19 06:38 PM
String trimmer line size preference?
by 92saturnsl2. 04/20/19 06:38 PM
What would you do?
by Yuk. 04/20/19 06:26 PM
Best Time For Battery Sales
by borgward. 04/20/19 05:08 PM
2006 chrysler town and country 5w30 o.k.?
by hooperswish1. 04/20/19 04:56 PM
??? Messages on Chevy 2500
by lukejo. 04/20/19 04:50 PM
Koi (carp) bait
by wings&wheels. 04/20/19 04:30 PM
More power from my weed wackers?
by Chris142. 04/20/19 04:24 PM
Is your tool chest/tool area well organized?
by ZZman. 04/20/19 03:41 PM
Mixing of vicosities
by Matt97. 04/20/19 02:56 PM
Tired Of These YouTube "Cover Bands"
by Warstud. 04/20/19 02:47 PM
Digital Torque Adapter
by LeakySeals. 04/20/19 02:12 PM
Lenovo c930 vs Asus ZenBook UX433FN
by mcrn. 04/20/19 01:34 PM
Food health standards overrated?
by BossMoss. 04/20/19 01:20 PM
Ubuntu 19.04 is out
by simple_gifts. 04/20/19 01:02 PM
Fixing microwave handle
by Donald. 04/20/19 12:55 PM
Lost an engine, rebuild, replace, scrap?
by CBR.worm. 04/20/19 12:22 PM
Floor jack oil recommendation
by Patrick0525. 04/20/19 11:40 AM
Tundra73, Dkouz, MichaelT1981, Rahstyle, Dlbaldwin01
67860 Registered Users
115 registered members (92saturnsl2, Alfred_B, aba4430, AMGTHIS, AdditiveOCD, 2002 Maxima SE, 6 invisible), 1,991 guests, and 23 spiders.
Topics287,798
Posts4,934,734
Members67,860
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Coolant change time or mileage [Re: kschachn] #4883370
09/29/18 10:48 PM
09/29/18 10:48 PM
N.A.
Onetor Offline
Onetor  Offline
N.A.
Originally Posted by kschachn
Originally Posted by Onetor
Don't forget that coolant also lubricates the Water Pump etc. So the additives need to be replenished, etc. I agree about the heat being detrimental!
Which parts are lubricated by the coolant? The water pump bearings are actually protected from the coolant by seals. Once the seal deteriorates and is breached by the coolant the bearings will destruct in short order.
I stand corrected. Ty
N = R* x fp x ne x fl x fi x fc x L
Re: Coolant change time or mileage [Re: motor_oil_madman] #4884647
10/01/18 03:01 PM
10/01/18 03:01 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I do radiator spill/fill's at 1/2 the allowable intervals that way the coolant in the system is always fresh all the time and there is no need for flush/fill. I have driven all my vehicles to their junk points with original water pumps and radiators.
'18 Caravan - 30k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Coolant change time or mileage [Re: motor_oil_madman] #4891612
10/09/18 07:01 AM
10/09/18 07:01 AM
FL
mcrn Offline
mcrn  Offline
FL
I just went 6 yrs on my nissan with 75k miles....makes me feel bad I waited a yr too long,
2012 Nissan Rogue
Re: Coolant change time or mileage [Re: motor_oil_madman] #4908908
10/29/18 04:39 AM
10/29/18 04:39 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I go by time for the coolant. I'd never hit the mileage stated in the owners manual vs. the time in use for the coolant.
God Bless Our Troops
Re: Coolant change time or mileage [Re: motor_oil_madman] #5007523
02/11/19 12:05 AM
02/11/19 12:05 AM
Monroe, WA
KevinP Offline
KevinP  Offline
Monroe, WA
There are two concerns, coolant degradation as it acidifies with age, and inhibitor package depletion.
You can check how the glycol is aging with a pH meter (strips won't give you enough resolution). You should make sure your pH meter is calibrated against pH buffer standards because the probes quickly drift out of calibration, especially when they are not stored correctly. The pH should be around 8.0 in a healthy glycol solution for automotive use. And yes.... it ages quicker with heat. The degradation is a chemical reaction and ethylene glycol primarily degrades into glycolic acid (some oxalic, some formic) and all chemical reactions proceed quicker with energy input. Thus ethylene degrades into the acids quicker at higher temps than it would at lower.
I've also seen studies that show inhibitor degradation over time. The azoles, in particular, drop with time. I'm not sure of the mechanism whether it is bonded to copper/brass as the inhibiting layer or if it is lost in the non-sealed system. Either way, you could just start at a higher level. The assumption is that it will be run at 50/50 so run it at 65/35 so you have more to start with.
It is so cheap to dump it on a regular basis that I err on the side of caution.
Page 2 of 2 1 2
