Carbon - Soot
by WyrTwister. 05/22/19 08:07 AM
Radiator Half Full
by Mark72. 05/22/19 07:04 AM
Another RA discount code#
by Char Baby. 05/22/19 06:44 AM
Water leak from passenger door?
by HoosierJeeper. 05/22/19 06:40 AM
Motul 300v 5w40 vs Redline 40WT racing in BMW racecar
by junkyard_sal. 05/22/19 06:23 AM
Someone smoked in my company truck
by Cujet. 05/22/19 06:19 AM
Cross Country Oil Choice ?
by ChrisD46. 05/22/19 03:06 AM
Calling all gen2 3.5 Ecoboost owners
by double vanos. 05/21/19 11:51 PM
15 Chevy malibu
by earlyre. 05/21/19 11:16 PM
Align 3 blade deck
by rekit. 05/21/19 10:51 PM
Cut the cord, finally
by 14Accent. 05/21/19 10:29 PM
Av Gas 100LL in small engines and other things
by earthmover1980. 05/21/19 10:11 PM
Yamaha R1 on the Autobahn
by AZjeff. 05/21/19 09:11 PM
Sea Foam question
by vavavroom. 05/21/19 08:40 PM
Study on detergent additives and abrasiveness
by addyguy. 05/21/19 08:33 PM
ST9688 oil filter on motorcycle?
by AuthorEditor. 05/21/19 05:56 PM
52Voodoo, HondaHrX, DirkDiggler87, Fordpuppy, Geowebby
68175 Registered Users
102 registered members (andrewp1998, 97prizm, 2009Edge, Anders, 1978elcamino, 2004tdigls, 14 invisible), 1,794 guests, and 33 spiders.
Topics289,227
Posts4,964,972
Members68,175
Most Online2,967
Mar 10th, 2019
Head with leaky valves advice needed #5007135
02/10/19 05:48 PM
02/10/19 05:48 PM
Raleigh ,NC CSA
rshaw125 Online content OP
rshaw125  Online Content OP
Raleigh ,NC CSA
A buddy of mine had persistent misfires on his Taurus. Compression test showed two weak cylinders. He pulled the head and laid it on it's side. Filled the ports with water after a few minutes a tiny dribble out of one valve. 1 of 6 intake valves. DOHC Ford. Then exhaust side . Two valves with little dribbles after a few minutes. Are these little dribbles enough to cause the misfire and low compression? The engine has around 150,000 miles. Is this just normal wear??
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Head with leaky valves advice needed [Re: rshaw125] #5007142
02/10/19 05:56 PM
02/10/19 05:56 PM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
Since the head is off and there is leakage from the valves, now would be a good time to get the head reconditioned especially since the engine has 150,000 miles on it.
Re: Head with leaky valves advice needed [Re: rshaw125] #5007153
02/10/19 06:02 PM
02/10/19 06:02 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
Pouring water in the combustion chamber now? Yes it will show the leaking valve seats if they a fairly bad. Will cause lower compression, yes, but he really should have done a comp test before removal. compression is often lost thru rings or valves. At this point he is in no man's land till he has a valve job done and mounts heads back on motor. Yes, seems like fairly normal wear for a Taurus....
As for valves causing misfire? IDK, If its the intake, and they leak bad enough, yes. The ECU should show a code for misfire if its OBD2, and its the ignition system. Atleast it should...If its back firing thru an intake valve, probably is not going to log a code.
O'pps my bad, he did a comp test, sorry! Nice German car you have by the way! I approve...
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Head with leaky valves advice needed [Re: rshaw125] #5007170
02/10/19 06:12 PM
02/10/19 06:12 PM
Raleigh ,NC CSA
Raleigh ,NC CSA
Thanks for the replies. Yes a compression test revealed the weak cylinders. Wet and dry. Rings are tight. After codes for misfires. The leakages are just dribbles. i was expecting a flow of water. No obviously burned valves.
2016 Ford Edge 2.0
2006 Explorer SOLD
Re: Head with leaky valves advice needed [Re: rshaw125] #5007212
02/10/19 06:53 PM
02/10/19 06:53 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
There could be different reasons. Slightly bent valve, weak valve springs, worn seats.
Best to take the head in and have it rebuilt and put it back on.
'18 Caravan - 34k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Head with leaky valves advice needed [Re: StevieC] #5007259
02/10/19 07:22 PM
02/10/19 07:22 PM
RI
mattd Online content
mattd  Online Content
RI
What exactly were the compression test results? Valve leakage can certainly cause misfires
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Head with leaky valves advice needed [Re: rshaw125] #5007275
02/10/19 07:32 PM
02/10/19 07:32 PM
Raleigh ,NC CSA
Raleigh ,NC CSA
The two bad cylinders were 55 and 65 PSI. The good cylinders were 145 - 155.
2016 Ford Edge 2.0
2006 Explorer SOLD
Re: Head with leaky valves advice needed [Re: rshaw125] #5007300
02/10/19 07:54 PM
02/10/19 07:54 PM
WA
DeafBrad Offline
DeafBrad  Offline
WA
I don't claim to be a professional mechanic or anything. But what is a dribble with water should be significant when the air is under compression.
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: Head with leaky valves advice needed [Re: DeafBrad] #5007332
02/10/19 08:19 PM
02/10/19 08:19 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Yep. If liquid will pass air will really leak past.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Head with leaky valves advice needed [Re: rshaw125] #5007363
02/10/19 08:50 PM
02/10/19 08:50 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Little dribbles after several minutes?
No - - Those will not affect the way the engine runs.
I have seen heads where liquid would almost run out as fast as it poured in - - STILL, no misfires!
But you could SURE hear the whistle in the exhaust when cranking it to start it!!!!!!
Re: Head with leaky valves advice needed [Re: rshaw125] #5007366
02/10/19 08:51 PM
02/10/19 08:51 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You should have done a "DRY" test followed by a "WET" test.
I honestly do not think the head is your problem, if you got "Just a tiny dribble" after several minutes.
Re: Head with leaky valves advice needed [Re: rshaw125] #5007405
02/10/19 09:18 PM
02/10/19 09:18 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Sure, numbers like that can and do cause misfires, under 90 psi can cause it and the lower it goes the greater the odds. That kind of leakage is enough to cause the low compression.
Seeing as a wet and dry test was done I think you found the issue.
Edit: You should check the valve guides and cam lobe/lift also, worn guides can cause erratic seating in the running engine and worn lobes can cause low compression, a dial indicator is be the easiest way to tell on a cam in block engine.
Re: Head with leaky valves advice needed [Re: DeafBrad] #5007451
02/10/19 10:14 PM
02/10/19 10:14 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
"But what is a dribble with water should be significant when the air is under compression."
Correct!
Re: Head with leaky valves advice needed [Re: 46Harry] #5007613
02/11/19 07:24 AM
02/11/19 07:24 AM
NY
demarpaint Offline
demarpaint  Offline
NY
+1 And in all honesty if he plans on keeping the car he might as well do the other head, and check the cam.
God Bless Our Troops
Re: Head with leaky valves advice needed [Re: rshaw125] #5007617
02/11/19 07:35 AM
02/11/19 07:35 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
What was done to determine "rings were tight"?
What year Taurus?
2015 Ford F250 w/Powerstroke
