Mobil 1 0w40 vs Pennzoil platinum 0w40
by Dragon44. 05/20/19 01:17 AM
Another SCORE !!!
by GMguy84. 05/20/19 12:14 AM
Replacing PP 5W-30 with PP 10W-30?
by John344. 05/20/19 12:03 AM
Really need help!!Ngk Spark plug vibration
by Rohan. 05/19/19 11:20 PM
No joy in Mudville...
by DeepFriar. 05/19/19 10:18 PM
Google cuts off Huawei's Android license
by spackard. 05/19/19 10:10 PM
Interstate batteries?
by daz. 05/19/19 07:27 PM
Sunoco 95 octane Premix at Menard's
by Spartanfool. 05/19/19 07:26 PM
Motor mounts @ rock auto?
by Insertcoolname. 05/19/19 06:58 PM
Does rolling coal damage catalytic converters?
by atikovi. 05/19/19 06:29 PM
Misfire and fuel injeection
by vavavroom. 05/19/19 04:50 PM
First drive in my 300CD in ~ 7 years...
by JHZR2. 05/19/19 04:32 PM
8 Year Review 2007 MDX
by madRiver. 05/19/19 03:18 PM
Fram Ultra...any concern?
by mv6845. 05/19/19 01:24 PM
2015 F150 front and rear diff fluid
by Buzzinhalfdozen. 05/19/19 01:13 PM
Race gas for my ope?
by Chris142. 05/19/19 12:18 PM
Gas Additives
by coopns. 05/19/19 11:44 AM
REview Frontier Airlines
by madRiver. 05/19/19 11:35 AM
leot, trailhead2004, Jwwright, RonC, JunkdrawerDog
68151 Registered Users
44 registered members (cjolson140, Aaron_Patton, caprice_2nv, CDX825, BlakeB, 3 invisible), 720 guests, and 34 spiders.
Topics289,119
Posts4,962,639
Members68,151
Most Online2,967
Mar 10th, 2019
'09 TSX Engine Issue Limp Mode Timing Chain #5007412
02/10/19 09:28 PM
02/10/19 09:28 PM
northern Alabama
benjamming Offline OP
northern Alabama
2009 Acura TSX with 75k miles purchased from only other owner. Issue was deemed (by Acura dealership) to be a stretched timing chain. Engine would turn over but not start. Coworker didn't want to deal with it so sold at quite a low price. Changed timing chain, tensioner, guides, and VTEC actuator with genuine Honda parts.
Now the engine starts and runs ok (initially) but has a tap or tick that sounds like its on the exhaust side of cylinder 3. It sounds & feels like an exhaust pipe. Also, cylinder 3 has 50-70 psi lower compression that 1, 2, or 4. It is still in spec (~130 psi). It runs & drives ok for a few miles with no CEL. Then the CEL comes on & sometimes is accompanied by a "check emissions" warning. After a few more miles, the CEL begins blinking and it goes into what appears to be limp mode, i.e. low power & will not go > 3000 rpm. The only code is for cylinder 3 misfire. Even when it's running badly, the #3 coil can be disconnected, & it makes a difference so it is actually firing.
Also noticed that when the oil filler cap is removed there is a lot of pressure.
Any thoughts - bad valve, piston, rings? Two issues? What causes higher crankcase pressure like that?
Thanks.
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007423
02/10/19 09:41 PM
02/10/19 09:41 PM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
Possible valve kissed the piston and damage occurred. Maybe a cheap harbor freight bore scope can see in there and confirm.
I hope you bought very cheap. May need an engine or at least a rebuild.
Rod
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007443
02/10/19 10:07 PM
02/10/19 10:07 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Adjust the valve clearance's to spec, Perform Cam-Crank Correlation procedure via a capable scan tool.....Hail Mary attempt but it may fix the issue.
I would suggest a leak-down test after running the overhead, But few have a leak-down tester?
2001 Chevy Camaro L92/4L80E
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007448
02/10/19 10:10 PM
02/10/19 10:10 PM
MN
Tman220 Offline
Tman220  Offline
MN
Was the head pulled? Valves checked? My money is on a bent valve. I would perform a leak down test on your weak cylinder and you will find out pretty quickly where that compression went.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 160k
2004 Civic LX M5 178k
2007 Camry 2.4 232k
2016 Victory Vegas
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007469
02/10/19 10:37 PM
02/10/19 10:37 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
That is awfully low mileage for the chain to stretch, do you know what caused it?
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol Edge 0w40 / OEM filter
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: gregk24] #5007509
02/10/19 11:39 PM
02/10/19 11:39 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Lack of maintenance? I've done more K24 timing chains than any other Japanese engine with the Toyota 1GR-FE being second. Japanese makes being immune to timing chain stretch/wear is a myth......Not surprising given that owners will sweep it under the rug vs screaming from the hill tops on a Domestic & European make.
I don't see many internet complaints on 2AZ-FE head gaskets/Cylinder block threads pulling out......Anything to save face!
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007549
02/11/19 01:20 AM
02/11/19 01:20 AM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
My money is on a bent valve as well. Timing chain issues aren't unheard of with this engine, but the jury is out on if the VTC actuator is the cause or not.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007637
02/11/19 08:08 AM
02/11/19 08:08 AM
FL
Kozman011 Offline
Kozman011  Offline
FL
Sorry I can't help with the issue, but my 06' Acura has 225K on it and it runs like the day I bought it. The only thing i put in it is new oil and alternators. Lack of maintenance is the most likely culprit with your stretched chain. The timing chain in these things love nice, clean oil. Never paid attention to the OLM since day one. New synthetic every 4-5K. Good luck and please keep us posted.
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007676
02/11/19 09:01 AM
02/11/19 09:01 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
The thing that really scared me is the high crankcase pressure. Bent valves do not cause high crankcase pressure.
only massive blowby. That is not a good sign. This is why I suggested a cheap harbor freight bore scope
Or just pull the heads, shame to waste all the parts though.
Rod
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007699
02/11/19 09:23 AM
02/11/19 09:23 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Thanks.
Check the spool valve and filter and related components. I know little about this particular engine buy have seen bad spool valves on the V6 cause similar problems.
The spool valves from Standard were reboxed OE (the last one I bought for a V6) I don't know if they still are but they are priced right.
Edit: Rock has spool valve and filter for this one.
https://www.rockauto.com/en/moreinfo.php?pk=8479932&cc=1442648&jsn=373
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: dishdude] #5007703
02/11/19 09:26 AM
02/11/19 09:26 AM
New England
madRiver Offline
madRiver  Offline
New England
My indy mechanic gets a few where owners decide to overstretch the oil changes to the 7.5k - 10k level and the chain gets ruined. He has done a few K24 engines over
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: madRiver] #5007855
02/11/19 11:59 AM
02/11/19 11:59 AM
RI
mattd Offline
mattd  Offline
RI
I would say there is piston damage if there is that much pressure out of the oil cap. First thing i would do is a cylinder leakage test to confirm or a boroscope down the plug hole.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007982
02/11/19 01:43 PM
02/11/19 01:43 PM
pa
benjy Offline
benjy  Offline
pa
this is like reading a book, looking for the ending-solution
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5007991
02/11/19 01:58 PM
02/11/19 01:58 PM
Huntsville, AL
AH64 Offline
AH64  Offline
Huntsville, AL
I'm the subject TSX owner. I have borescoped and saw no obvious damage to the piston. I would like to try a leak-down test but do not have the equipment. I assumed it was a valve but the crankcase pressure has me worried.
Re: '09 TSX Engine Issue Limp Mode Timing Chain [Re: benjamming] #5008063
02/11/19 03:32 PM
02/11/19 03:32 PM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
You can do a leak down test of limited merit, take a sued correct size plug and break out all the ceramic. Then epoxy in a hose fitting of some appropriate size and pressurize the offending cylinder with at least 50 psi air. If you have air escaping out the oil fill port, then you have some sort of ring seal problem on that cylinder. For a reality test you can compare to one of the good cylinders. You can listen at the intake and tail pipe for air escaping, that confirms the diagnosis.
This does not give you any number so it is subjective. Nothing wrong with that, just some folks demand a number of some sort.
Rod
