Fat Wallet Forum
by LazyDog. 02/21/19 10:09 AM
Orange washer fluid?
by atikovi. 02/21/19 10:01 AM
Recommended laptop carrying case
by paulri. 02/21/19 09:47 AM
Collagen and Gelatin for protein supplement
by Lolvoguy. 02/21/19 09:36 AM
Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
103 registered members (240_Ed, aquariuscsm, Bambam, aleneros, atikovi, 14 invisible), 1,663 guests, and 51 spiders.
Topics284,603
Posts4,873,213
Members67,298
Most Online2,548
Feb 16th, 2019
Page 2 of 2 1 2
Re: Head with leaky valves advice needed [Re: rshaw125] #5007626
02/11/19 06:55 AM
02/11/19 06:55 AM
Raleigh ,NC CSA
rshaw125 Offline OP
rshaw125  Offline OP
Raleigh ,NC CSA
It's a 2004 DOHC. Dry compression test followed by wet. The two bad cylinders saw no improvement from added oil.
Visually the cam lobes look like new.
The head in question is going to the machine shop Wednesday. Trying to decide if the other head should go even if it does not leak water.
Thanks for the replies.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Head with leaky valves advice needed [Re: rshaw125] #5007668
02/11/19 07:47 AM
02/11/19 07:47 AM
RI
mattd Offline
mattd  Offline
RI
Did you perform a leakdown test?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Head with leaky valves advice needed [Re: rshaw125] #5007670
02/11/19 07:49 AM
02/11/19 07:49 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Originally Posted by rshaw125
It's a 2004 DOHC.
Many years ago I worked in a machine shop, I learned quite a bit from some of the best machinists on L.I. The other head has just as much wear as the head in question, only it is not showing any symptoms, yet. You're halfway there labor wise to having that head done. Having said that, and forgetting ethics, if you're looking to sell the car fix the head in question and let the next person worry about it. If you want to keep the car, or care about ethics I'd do both heads. Imagine 6 months from now, or possibly less having to rip everything apart to do the other head. We are not talking a low mileage car here. I would say 8 out ten times we did heads in pairs.
God Bless Our Troops
Re: Head with leaky valves advice needed [Re: rshaw125] #5007673
02/11/19 07:51 AM
02/11/19 07:51 AM
Southeast
meep Offline
meep  Offline
Southeast
stretched timing belt caused misfires/stumbles at idle and low rpm for me.
~50psi is very low pressure.
leaky EXH valve can also cause misfire if it's developing hotspots and causing preignition.
2018 F150
2015 crv (wifey!)
Re: Head with leaky valves advice needed [Re: 46Harry] #5007674
02/11/19 07:52 AM
02/11/19 07:52 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Originally Posted by 46Harry
Since the head is off and there is leakage from the valves, now would be a good time to get the head reconditioned especially since the engine has 150,000 miles on it.
Exactly what I was thinking .
Wyr
God bless
Re: Head with leaky valves advice needed [Re: mattd] #5007687
02/11/19 08:12 AM
02/11/19 08:12 AM
Raleigh ,NC CSA
rshaw125 Offline OP
rshaw125  Offline OP
Raleigh ,NC CSA
No. The two low compression cylinders were also the one's that were misfiring. Also the one's with the leaky valves.
2016 Ford Edge 2.0
2006 Explorer SOLD
Re: Head with leaky valves advice needed [Re: rshaw125] #5007713
02/11/19 08:40 AM
02/11/19 08:40 AM
missouri
ragtoplvr Online content
ragtoplvr  Online Content
missouri
Water is a poor choice to leak test valves, it normally does not wet out the surfaces and with the surface tension it normally takes a pretty big hole to leak thru without pressure. Alcohol is a better choice. Bet those valves would gush with alcohol. If the head is still on the engine the alcohol will burn off evaporate much quicker but you still must worry about hydrostatic lock.
Re: Head with leaky valves advice needed [Re: rshaw125] #5008274
02/11/19 06:42 PM
02/11/19 06:42 PM
Arkansastan
Propflux01 Offline
Propflux01  Offline
Arkansastan
Leak down test would have given more info. Since the head is off, recondition it, and press on with pride. If the misfire stops, you will know why.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Page 2 of 2 1 2
Moderated by  ekpolk
