Fat Wallet Forum
by LazyDog. 02/21/19 10:09 AM
Orange washer fluid?
by atikovi. 02/21/19 10:01 AM
Recommended laptop carrying case
by paulri. 02/21/19 09:47 AM
Collagen and Gelatin for protein supplement
by Lolvoguy. 02/21/19 09:36 AM
Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
111 registered members (ABCarr, aquariuscsm, 240_Ed, aleneros, atikovi, 14 invisible), 1,676 guests, and 51 spiders.
Topics284,604
Posts4,873,229
Members67,298
Most Online2,548
Feb 16th, 2019
02 Volvo S40 coolant capacity #5007059
02/10/19 03:54 PM
02/10/19 03:54 PM
The Motor City
Kestas Online content OP
Kestas  Online Content OP
The Motor City
While working on the Volvo S40, I drained the radiator and disconnected the lower radiator hose. I captured 6 qts of coolant. The published capacity of the system is 6 qts. Did I truly drain ALL the fluid? I always thought some was left in the system (e.g., engine block, heater core).
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007081
02/10/19 04:08 PM
02/10/19 04:08 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I’ve seen other Volvo’s holding 9 quarts. Maybe check your data? smile
If you want the job done right......do it yourself.
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007101
02/10/19 04:22 PM
02/10/19 04:22 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Your right..... there's still some in the system. Just run that and drain the radiator again later this week when it warms up.
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007109
02/10/19 04:30 PM
02/10/19 04:30 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
6 quarts doesn't seem like much. Could it be the radiator capacity?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007285
02/10/19 06:44 PM
02/10/19 06:44 PM
CA
The Critic Offline
The Critic  Offline
CA
Prodemand shows 6.0 quarts as well.
2011 Toyota Prius - 184k - M1 EP 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007359
02/10/19 07:47 PM
02/10/19 07:47 PM
The Motor City
The Motor City
I sure hope so. I depend on the published data to refill it with the proper concentration after flushing.
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007372
02/10/19 07:55 PM
02/10/19 07:55 PM
CA
The Critic Offline
The Critic  Offline
CA
Why are you flushing the system? Contamination with oil?
I haven't flushed a cooling system in 10+ years. We don't flush anything at our shop either; everything gets a drain and refill with the OEM spec coolant. Then again, I work on Asian makes. Not sure what Volvo specifies, but I would not bother with flushing unless it is part of the OEM service procedure for coolant replacement.
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007472
02/10/19 09:45 PM
02/10/19 09:45 PM
The Motor City
The Motor City
Probably because old habits die hard. When I started wrenching, cooling systems needed flushing.
For this task I'm replacing a leaky radiator.
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5007554
02/11/19 12:46 AM
02/11/19 12:46 AM
Green Bay, Wisconsin
DejaVue Offline
DejaVue  Offline
Would think there's still some coolant in the block.
I don't know what engine is in your particular S40, but some engines such as the 2.5 have a fairly obvious engine block drain on the exhaust side.
Re: 02 Volvo S40 coolant capacity [Re: Kestas] #5008133
02/11/19 03:50 PM
02/11/19 03:50 PM
The Motor City
The Motor City
That Volvo model only came with one engine, 1.9L turbo.
Moderated by  ekpolk
