NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
I wish my Camaro was this color!
by clinebarger. 07/15/19 09:19 PM
2019 Crosstrek 2500 Mile Review
by Al. 07/15/19 09:00 PM
Panasonic Cockpit Radio
by dishdude. 07/15/19 08:36 PM
97 Honda Civic won't crank
by Merek. 07/15/19 08:22 PM
Farmall alternator
by chilson450. 07/15/19 08:19 PM
30K and Hyundai ATF?
by flinter. 07/15/19 07:43 PM
'03 Suburban Quirks
by A_Spruce. 07/15/19 06:51 PM
new clutch shop $1500
by sirgerman. 07/15/19 06:45 PM
Pain in the rear transmission service...
by 14Accent. 07/15/19 06:38 PM
Longer Canister Fram Ultra Part #?
by gwarrior4u. 07/15/19 06:27 PM
Rats! I need bodywork
by PeterGreen. 07/15/19 06:15 PM
ATF-4?
by WillB. 07/15/19 05:58 PM
Rotunda AOD Transmission Rebuild Tool Kit
by TooManyWheels. 07/15/19 04:44 PM
No more Champion plugs for me LOOK!
by bchannell. 07/15/19 04:11 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68669 Registered Users
28 registered members (BlueOvalFitter, Ammofirst, Bailes1992, A_Spruce, AC1DD, 1WildPig, 5 invisible), 892 guests, and 24 spiders.
Topics291,925
Posts5,013,437
Members68,669
Most Online2,967
Mar 10th, 2019
Use the A1 or A3/B4 #5006256
02/09/19 10:11 PM
02/09/19 10:11 PM
usa
jerremy93 Offline OP
usa
Hi, im doing my first ever oil change to save money from a mechanic .. My manual says "5W-30 A3/B4 OIL like Castrol Edge Brand" .. I ended up Buying "Mobil 1 5W-30 Newer Vehicle Formula Full Synthetic Engine Oil" A1 - ...Question is what will happen if i use the A1 vs the A3/B4 thats in my manual ??? will it damage my engine ?? i can take it back and exchange it if you guys think its not ok ..
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006269
02/09/19 10:22 PM
02/09/19 10:22 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I’ll let another bitoger field this one. I’m eating dinner.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Use the A1 or A3/B4 [Re: 1JZ_E46] #5006275
02/09/19 10:27 PM
02/09/19 10:27 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Take it back and buy an oil that meets the required spec. One does not need to know what it means if you don’t want to, all you really need to know is how to read the container (and your manual). Easy.
So if you’re familiar with the long answers here on Bitog does that mean you’ve been around before?
Also what vehicle and engine is this for?
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Use the A1 or A3/B4 [Re: 1JZ_E46] #5006285
02/09/19 10:44 PM
02/09/19 10:44 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Yeah, there are some real dumb questions being asked here within the past 3 weeks. Simply amazing
Re: Use the A1 or A3/B4 [Re: 53' Stude] #5006290
02/09/19 10:50 PM
02/09/19 10:50 PM
usa
usa
What would you do ? use the A1
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006294
02/09/19 10:54 PM
02/09/19 10:54 PM
5600 feet elevation, Arizona
double vanos Offline
First off welcome
If your manual tells you to use an A3 oil, that’s a European spec for BMWs, VW, etc. Generally speaking Euro oils are higher in the viscosity range for a certain weight oil. HTHS figures are higher too. They’re different than ILSAC or ACEA which are formulated more for mileage. If you need an A3 oil take your oil back and exchange it for some A3 oil in the correct weight. Out of curiosity, what car is this going in?
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006296
02/09/19 10:59 PM
02/09/19 10:59 PM
Monroe, WA
KevinP Offline
KevinP  Offline
Monroe, WA
Take it back and follow your manual. Ignore everything else you read on this forum.
You can get the Pennzoil Platinum Euro 5W-30 at Walmart for $22.68 per 5 qt and there is a $10 rebate that takes 5-minutes to fill out. Hard to get much cheaper than that and it meets your OE spec.
Re: Use the A1 or A3/B4 [Re: double vanos] #5006309
02/09/19 11:15 PM
02/09/19 11:15 PM
usa
usa
COOLthanks - its a 'HSV E3 R8' my dad imported it .. same car as in this video https://www.youtube.com/watch?v=IkIGOLANmrM
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006327
02/09/19 11:26 PM
02/09/19 11:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
HSV ... Australia only?
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006345
02/09/19 11:47 PM
02/09/19 11:47 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Mobil 1 0-40 FS would meet your specs and is cheap at Walmart... rebates make it REAL affordable!
But isn’t that a GM V8?....I would think any Dexos 1 gen 2 oil would also do.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006352
02/09/19 11:59 PM
02/09/19 11:59 PM
WA
OilUzer Offline
OilUzer  Offline
WA
approved
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006408
02/10/19 03:11 AM
02/10/19 03:11 AM
BiH, Europe
BobGoblin Offline
BobGoblin  Offline
BiH, Europe
A1 is obsolete now. A5 is direct replacement.
Car: KIA Ceed JD 2017 (1.4 petrol - kappa III - G4LC)
Oil recomended: 5w30, ACEA A5
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006412
02/10/19 03:39 AM
02/10/19 03:39 AM
Balearic Islands , Spain
FordCapriDriver Offline
A1 is an obsolete spec, it has been replaced by A5, both are specifications targeted towards fuel economy.
A3/B4 is the opposite, it's a spec designed for high performance engines, so i would use an A3/B4 oil if that is what is specified.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40
G40 Si-OAT coolant in both
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006431
02/10/19 06:14 AM
02/10/19 06:14 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
If you are an American with EUropean ancestors...F....that ILSAC sh... And use ACEA A3/B4 smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Use the A1 or A3/B4 [Re: jerremy93] #5006540
02/10/19 09:30 AM
02/10/19 09:30 AM
Somerset, UK
240_Ed Offline
240_Ed  Offline
Somerset, UK
Use an A3/B4 oil. Engines that spec A1 or A5 oils can use A3 oils in most cases, but those that specify an A3 oil generally should not use an A1 or A5. A3/B4 oils are plentiful and often on offer, so just go for whatever brand name 5w30 A3/B4 is available cheaply, fill up and sleep soundly.
1992 Volvo 240 (B200F) - Castrol Magnatec 10w40, Mann W917 filter
2001 Volvo V70 (B5244S) - Shell Helix HX8 ECT 5w40, Mann HU819X filter
