The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
modem in 1 room want phone in another room
by raaizin - 08/21/19 02:17 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
45 registered members (Capt, BlakeB, BrianF, AndyB, 8 invisible), 1,201 guests, and 26 spiders.
Topics293,634
Posts5,043,783
Members69,025
Most Online3,532
Jul 30th, 2019
Tacoma, codes P0441, P0446 #5005609 02/09/19 10:31 AM
Sayjac Offline OP
Check engine light on an 01 came on a week ago Thursday, one the colder days here before warm up. Got out my trusty old Actron basic code reader, got topic codes. Evap system, research suggested several possibilities, worst evap canister and/or tank purge/rollover valve. Easiest, bad gas cap and evap vacuum lines. Gas cap relatively new Stant Cap purchased last year. Did have a couple of OE canister hoses that were cracked. One short, one longer to top of intake plenum. Started there.
Having a gift card went first to AAP. Had some hose that might have worked, but OD much smaller. First Napa store tried to sell me fuel hose, said same thing. Uhh, no. Then to the Toyota dealer, wow useless as.....think anatomical part on male bovine. Would have liked to purchase actual hose pieces as can be seen many bends and would be best option. Lacking that at least some OEM type hose by the foot with same ID and OD. No joy on either and a total waste of time. Then to another Napa store, Flowers Family with stores in NC and apparently Va. Had some hose by the foot with very close if not identical ID, OD slightly smaller but workable, 3 ft ~$1.80. As can be seen had to extend the hose U curve of the replacement hose so as to not restrict flow.
Erased codes haven't come back in well over 100 miles and over a week, but didn't come back after erasing them immediately with old hose. Time will tell. Did buy a new OEM Toyota gas cap (pricey) too even though Stant likely fine, will save for spare. No didn't buy from local dealer, got it from an ebay seller.
Ideally having a smoke machine for this be best, but at this point didn't want buy even the ones like Scotty Kilmer hawks and sold on ebay. I'd have limited use. I see Pep Boys does test for ~$30, but it is Pep Boys. I've got zero complaints about the truck, ~155k miles only second check engine light I've gotten. First air-fuel ratio sensor, easy fix. If I ever sell this, even though MT trashed Tacoma recently, I'd buy another.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5005748 02/09/19 01:33 PM
R
rekit Offline
R
I also have 01 Taco, v6. Went thru this last year. I remember checking the solenoid vsv, it was ok. Could not test pressure sensor and they were Expensive!! if you could find one. I tried one from an Ebay junkyard. It was the exact part #, tho it said off a 96 Camry. $25 or so. Fixed my truck.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5005765 02/09/19 01:45 PM
das_peikko Offline
I see some of your hoses are using constant tension clamps.
It would have been a good idea to install those on your new hoses as well.
Re: Tacoma, codes P0441, P0446 [Re: rekit] #5005810 02/09/19 02:30 PM
Sayjac Offline OP
Point noted. What you see is exactly how they were fit, no clamps used on places seen without one. End of hose up on intake plenum had a tension clamp, used an extra piece of cut hose over the new hose to allow clamp to fit tightly. I would say the new Napa hose fits pretty tightly now, at least as tight as OE before the splits.
Originally Posted by rekit
...Could not test pressure sensor and they were Expensive!! if you could find one. I tried one from an Ebay junkyard. It was the exact part #, tho it said off a 96 Camry....
If code(s) return, I'll keep that in mind and if ok I'll pm you if I have questions about that sensor.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5005911 02/09/19 04:16 PM
M
michaelluscher Offline
M
I just fought similar EVAP problem on my Camry
$24 later for a OEM gas cap from my friendly Toyota parts man, it was fixed
If you don't hear/feel suction when removing it, it's bad
This is anecdotal, but I've had nothing but trouble with non OEM gas caps
'06 Toyota Camry SE V6 3MZ-FE 124k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5005933 02/09/19 04:46 PM
scionxa Offline
I have the locking version of the Stant on my 2009 Tacoma since the 2nd gen doesn't have a locking fuel door. I have had this cap for almost 10 years now. One thing that seems to help with seal life on the gas cap is applying a bit of dielectric grease to them when they are still new. They won't dry out and crack and you get a long life from them. I also have a Honda CRV whose original gas cap seal didn't get grease; it dried out after 6 years, and I replaced with OEM cap which DID get grease at install.
Re: Tacoma, codes P0441, P0446 [Re: michaelluscher] #5006054 02/09/19 07:30 PM
Sayjac Offline OP
When I removed the Stant cap yesterday to replace with the OEM I did hear/feel the suction. Don't regret the OEM cap purchase though. At times the Stant cap was very hard to get started turning for removal. I'm thinking the OEM cap will help with that. Your price on target with what I paid for the OEM cap.
I'll keep the dielectric grease on the cap seal tip in mind.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5006144 02/09/19 08:32 PM
das_peikko Offline
I'm thinking a constant tension clamp would prevent the end of the hose from splitting by constantly squeezing it.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5006287 02/09/19 10:46 PM
The Critic Offline
I have a Redline Readysmoke machine that rarely gets any use. If you want to pay the 2-way shipping fee, you can borrow it.
2011 Toyota Prius 1.8L - 195K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 138K - Mobil 1 EP HM 5W-30
Re: Tacoma, codes P0441, P0446 [Re: The Critic] #5006320 02/09/19 11:22 PM
clinebarger Online Content
Online Content
Interesting.....I use mine (Snap-on high volume) at least once a week.
2001 Chevy Camaro L92/4L80E
Re: Tacoma, codes P0441, P0446 [Re: clinebarger] #5006324 02/09/19 11:25 PM
The Critic Offline
I rarely see EVAP issues or vacuum leaks which require smoke testing.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5006338 02/09/19 11:39 PM
Online Content
I use mine to double check engine & transmission sealing before installation. Easiest way I've found to find pre-existing oil leaks as well.
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5006378 02/10/19 01:21 AM
M
mehullica Offline
M
Getting the evap monitor is tough on that year. Can you check to see if it’s passed with your code reader? Canister Close Valve will trigger those 2 codes. Since there’s no P0440, I’d say it’s the CCV or charcoal in the canister has cracked partially blocking airflow
Re: Tacoma, codes P0441, P0446 [Re: Sayjac] #5006496 02/10/19 08:44 AM
Sayjac Offline OP
So I put Actron Pocket Scan on Tacoma again this am, zero codes. Obviously good.
Critic I appreciate the offer, Googled it. Looks like a very nice piece of equipment. I'm thinking two way shipping could be rather costly, plus I wouldn't want to be responsible for any damage that could occur in shipping or otherwise. I do have a plan should codes return. Indy Honda shop that has done timing belt water pump service for me, has added Toyota service to his repertoire. I'd call and ask if he does smoke testing. Beyond that I would grudgingly consider PepBoys, IF done right price not whacked imo.
I'm thinking the suction sound and feel when gas cap removed was at least a good sign it's not the tank purge/roll over valve, that would not be diy for me. So what's left including evap canister is under the hood. Though options there can get costly I could service them. On the evap canister, I watched a couple youtubes showing leaks on same canister. One found at bottom seam with one those ebay type smoke machines. The other was found on one the canister top circular protrusions (there's two) that can been seen under old hose in posted pic. The former was fixed with something called Toyota Seal? The latter fixed with Epoxy Glue.
I will look for more of theToyota spring clamps. Part of the issue like not finding the OEM replacement hoses, unlike Honda where detailed parts diagrams with parts #s can be easily found on many online sites, Toyota much harder find ime. Most I can find is some separate parts, but especially for smaller parts have to guess if they are the ones I'm looking for. If I had the numbers I could have just gone to dealer with part numbers and tell the parts guy what I wanted/needed, or order online. As noted, dealer parts guy was no help.
Below is aforementioned Actron scanner purchased in 2008 for ~$42, might have been my first Amazon purchase. Nothing fancy, but it's paid for itself many times over.
