Carfax report 😳
by kstanf150 - 12/06/19 08:55 PM
2010 Honda Element 197k miles valvetrain pictrures
by SLO_Town - 12/06/19 08:31 PM
ADBV Failure FU XG-8A ,10K miles 13 months
by wrcsixeight - 12/06/19 08:29 PM
Michelin Defender on Civic
by jharrison - 12/06/19 08:14 PM
2012 GMC Terrain 3.0L V6 Valve Cover Replacement
by benjamming - 12/06/19 07:30 PM
Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
Stahle, BajaBu, Bayoubrad, Fog42, glassmaker
70053 Registered Users
102 registered members (4WD, 2009Edge, 2015_PSD, 67ZL1, AC1DD, advocate, 7 invisible), 1,984 guests, and 60 spiders.
Topics298,388
Posts5,134,303
Members70,053
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: SubieRubyRoo] #4999209 02/02/19 08:35 AM
T
Triple_Se7en Offline
T
Originally Posted by SubieRubyRoo
So the only way to prevent PCV vapors from contacting the backside of the intake valve is to either eliminate PCV; move to a system like a valve cover evacuator like race cars use that suck it directly into the exhaust; or to suck it out of the crankcase and compress the snot out of it, and then direct-inject it directly into one of the cylinders. That would prevent all fuel and oil from entering the intact tract...
My 3.5 five cylinder Colorado does not have a PCV. Not sure how it operates without it.
19' Hyundai Santa Fe 2.4 GDI - Valv Syn 5w30 / Napa Proselect filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Factory-fill oil / filter
04' Colorado 3.5 / Castrol Edge 0W40 / K&N filter
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: EngineeringGeek] #4999325 02/02/19 10:23 AM
StevieC Offline
It will have a breathing system instead. It has to have one or the other or the engine would explode from pressure.
'18 Caravan - 45k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: Mainia] #4999437 02/02/19 11:55 AM
K
KevinP Offline
K
Originally Posted by Mainia
Originally Posted by EngineeringGeek
Originally Posted by MolaKule
Engine oils and fuels are hydrocarbons.
A particular oil or fuel may reduce carbon deposits, but my bet is on the physcis that says anytime a hydrocarbon is burnt or subjected to high temperatures, there is no way it can eliminate or prevent carbon deposits.
The fuel never touches the backsides of the valves so that makes no difference in a D.I. engine although that's another common myth as it does have an impact with conventional port injection. But the oil vapors/mist/blowby/etc. from the crankcase DO contact the backs of the intake valves and that's the root of the problem. How much of that mix, and resulting deposits, are attributable to the oil is the key question. There does seem to be some consensus conventional oils leave more desposits than fully synthetic. But, as others have pointed out, what makes for a better synthetic is less clear even if Valvoline claims a 30% reduction with their Modern Engine formulation.
I respectively disagree with you, fuel will touch the backside of the valves in the valve overlap cycle. This could be why some cars carbon up more then others, Other variables are, engine bore size/cylinder head C chamber shape/cam timing & profile/port design/ignition mapping.
I was going to say the same thing. It is design issue.... some engineers have successfully designed fuel wash while the intake valve is open. Some have obviously failed and it also explains why a software update was part of the solution for engines that had a propensity for carbon formation on intake valves.
I'd still feel better with port injection but let's not pretend that all DI engines are going to have this problem. There are engineering solutions that have nothing to do with oil. They have to do with where/when the fuel is injected and design of the combustion process. A catch can and high NOACK oil are not the issues.
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: StevieC] #4999512 02/02/19 01:19 PM
T
T
I'll wear my Iron Man outfit, driving that non-PCV Colorado to 5:00 PM Mass. Then I'll light a candle and sprinkle that 4X4 with holy water.
That should keep myself safe thru the weekend, while running chores in that Colorado.
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: EngineeringGeek] #4999516 02/02/19 01:25 PM
B
Bullwinkle007 Offline
B
One way to clean the backside of the intake valves is to use carb and intake cleaner and spray it down into the intake while someone holds the throttle at 4k RPM, and spray the entire can. Then change the engine oil. That will also clean the intake manifold. I also clean the MAF sensor every oil change with MAF sensor cleaner
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: Bullwinkle007] #4999856 02/02/19 08:35 PM
E
EngineeringGeek Offline OP
E
I've seen zero independent proof any spray works. If you've ever seen and felt carbon build up on a D.I. intake valve it might as well be black concrete. So, no surprise, sprays, Seafoam, etc. don't seem to do much to magically soften and dissolve rock hard baked on carbon build up. There's a reason manufactures usually only recommend mechanical cleaning methods such as walnut shell blasting. Sprays don't work and there are plenty of independent tests that show they don't work.
@KevinP there is no "fuel wash" of the back side of the intake valves in a D.I. engine from all the research I've done. When the intake valve is open you have nothing but air and PVC vapors flowing IN to the cylinder and ideally nothing flowing the other way. The last thing you want for fuel efficiency is having raw direct injected fuel going back into the intake manifold where it would be wasted and that would also require some sort of reverse flow which would be hard to induce. Everything about efficient combustion for maximum fuel economy, lowest emissions, and greatest power, opposes dumping raw fuel mixture back into the intake manifold. i think it's a myth. If someone has factual evidence to the contrary I'd love to see it?
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: EngineeringGeek] #4999942 02/02/19 11:35 PM
StevieC Offline
I don't have pictures but I have seen the difference in the Veloster I'm maintaining with it.
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: EngineeringGeek] #5005855 02/09/19 02:10 PM
K
KevinP Offline
K
Quote
That is not completely true. The best example would be in an Atkinson cycle engine where combustion contents are partially forced back up the intake and these lead to BETTER fuel efficiency, not worse. What is washed up into the intake is not lost, it is used the next time you open the intake valve.
https://www.caranddriver.com/news/a...bustion-cycle-and-what-are-its-benefits/
https://www.youtube.com/watch?v=WKKILW3Zj_Y
https://www.youtube.com/watch?v=z45fM2N-4C4
And note.... Toyota engine management allows a vehicle to use both Otto & Atkinson operation in a non-hybrid. That would mean they would get fuel/air mixture on the back of the intake valve at least part of the time, presumably allowing for more intake valve cleaning.
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: KevinP] #5005929 02/09/19 03:41 PM
Bryanccfshr Offline
Additionally Toyota uses DS4 injection in multiple Engines. This means there is both port and direct injection. Based upon power demand. Most of the normal driving time the port injection is supplying a little squirt the traditional way, while direct injection operates at a lower rate. Under heavier load demands it switched entirely to direct injection.
Meanwhile The intake valve opening overlap with the piston compression cycle is a cool way to reduce the volume of the compression stroke under low load driving(rather than Atkinson I consider it temporary displacement reduction).
Regardless, intake valve deposits are not a concern at all in these. Direct injection performance on demand but admittedly you really have to put your foot into it to et it’s rated power.most of the throttle space is mapped for efficiency.
Originally Posted by KevinP
Quote
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Valvoline Modern Engine Preventing D.I. Carbon? [Re: Bullwinkle007] #5006205 02/09/19 08:19 PM
Z
ZeeOSix Offline
Z
Water injection cleans intake valves and pistons/combustion chambers pretty well.
Page 2 of 2 1 2
