Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
54 registered members (Astro_Guy, alarmguy, 69Torino, AndyB, Aero540T, 2015_PSD, 5 invisible), 681 guests, and 49 spiders.
Topics284,589
Posts4,872,986
Members67,294
Most Online2,548
Feb 16th, 2019
Page 2 of 2 1 2
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Triple_Se7en] #5006130
02/09/19 07:20 PM
02/09/19 07:20 PM
TX
parshisa Offline
parshisa  Offline
TX
What exactly is wrong with POA oil in TGDI? I’m running it with pretty good success and excellent UOAs
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Astro_Guy] #5006180
02/09/19 07:57 PM
02/09/19 07:57 PM
Texas, USA
PPWarrior Offline
PPWarrior  Offline
Texas, USA
Why run oil to the ground? I will stick to my 5k OCIs.
You can't correlate lab tests to real world wear and tear. I am sorry.
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Astro_Guy] #5006318
02/09/19 10:21 PM
02/09/19 10:21 PM
5600 feet elevation, Arizona
double vanos Offline
Time for some Castrol Magnatec 5w30! Run it 5k with a Honda filter for a couple rounds then send a sample to Blackstone. That’s my story and I’m sticking with it....
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Astro_Guy] #5006319
02/09/19 10:21 PM
02/09/19 10:21 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
Originally Posted by Astro_Guy
Originally Posted by Marco620
Nice car. Try a HTO-6 spec 5w30.
Isn't that a spec for turbos? I see that M1 EP 5w-30 meets it, so I may just give it a try.
Originally Posted by dave1251
Boring as Boring can be. You can go further if you like 15K miles easy.
Yes and no. Blackstone attributed the wear numbers on the first round to residual break in. Here we are ten thousand miles later and the numbers are heading in the wrong direction. The Iron is running nearly three times what I had seen in either of the Civics that preceded this car using the same oil and filter.
UOA's do not tell a thing about wear its in PPM you can not even see 29 PPM with a magnifying glass.
don't use.
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: PPWarrior] #5006322
02/09/19 10:22 PM
02/09/19 10:22 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
It's not even close to being ran into the ground. If you believe so studying UOA's for a couple dozen of hours will help you
don't use.
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: parshisa] #5006339
02/09/19 10:39 PM
02/09/19 10:39 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Latest reports say Group 2 and maybe Group 5?, may be better for LSPI / DI / Turbos. Then Group 3.... Last is Group 4 (PAO).
Info is in a couple threads here in the past month. Not sure exactly where.
If your engine is unaffected, then disregard my mention.
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Triple_Se7en] #5006344
02/09/19 10:47 PM
02/09/19 10:47 PM
TX
parshisa Offline
parshisa  Offline
TX
My engine is TGDI, low displacement. I ran loaded with calcium oil with 0 ill effects. Not the oil is the greatest contibutor to LSPI. Drive it as it should be driven and nothing will happen
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: parshisa] #5006348
02/09/19 10:52 PM
02/09/19 10:52 PM
You seem to have the answer. You should tell exactly that to the engineers testing all this stuff..... which by-the-way, still dont have any final answers.
They claim the affected engines resist best on Group 2.
I don't know anything about that low, medium or high displacement stuff. It's all French to me.
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Astro_Guy] #5006710
02/10/19 10:52 AM
02/10/19 10:52 AM
Pennsylvania
Astro_Guy Online content OP
Astro_Guy  Online Content OP
Pennsylvania
Getting back to the original point, the trend on Iron doesn't look good:
  • Miles on oil: 10,101 / 9,240 (+9%)
  • Iron: 29 / 16 (+81%)
I've been reading up on the K24W engine, and fuel dilution seems to be a recurring problem. The plan going forward is to drop this oil and filter at 6000 miles, send another sample for analysis, and replace it with 5w-30 M1EP and a new XG7317. I'll make a decision on the length of the next OCI based upon what the next lab report says, but somehow I don't envision this vehicle as being good for more than an 8000 mile OCI. Time will tell I guess.
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Astro_Guy] #5006921
02/10/19 02:12 PM
02/10/19 02:12 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
Astro... even though Dave1251 and I said similar things in different ways, I don't think you're getting it.
1. UOAs can ONLY look at particles <3 microns due to limitations of ICP testing.
2. Wear particles of any significance to your engine are WAY larger than 3 microns.
3. Wear particles big enough to be seen will end up in your filter, NOT in your UOA sample.
4. UOAs as used by nearly all "hobbyists" like here on the board are generally only useful for telling you whether or not a given oil is able to deal with your usage and mileage run, NOT how your engine is wearing while using that oil. If you want to have a much better idea of that, you need to look at different testing methods- filter wash analysis, analytical ferrography, etc... and those tests are all exceedingly cost prohibitive for a $20 oil change.
5. The chemical makeup of the oil can and will skew the UOA "wear metals" portion of the test, especially if you keep changing brands!- different chemistries can "chelate" left over deposits in your engine, making it appear you suddenly have a big jump in wear while nothing is actually going on. This is why there are guidelines for interpreting: a single data point means NOTHING in and of itself; and, changing oils and then retesting on that OCI makes the results of dubious value.
What does this mean? When you buy a car, change the oil with your intended use oil, and drive an OCI on it. Drain it and refill, and drive another OCI. Now if you want a UOA, you can test this fill and any going forward as long as you use the same brand and weight of oil. If you change brands or even weights, it skews the UOA some because of the leftover oil in the galleys and sump, and doesn't tell you much.
Back to the "chelating" effect- some oils seem to pull different metals out of the varnish/sludge/deposits left behind from other oils- Mobil1 seems to chelate iron, Pennz Platinum seems to chelate copper, and there are some others- what this means is when you switch to that oil and see a big jump in one certain wear metal, it almost certainly DOES NOT mean you suddenly have a near-catastrophic event going on in your engine! You need at least 3 oil analyses to identify a trend, and so that you don't severely skew your data and cloud the issue, I would keep using the same brand and weight of oil you did the first time, and maybe just shorten the OCI by 2-3k for the next two changes. Then, make the decision if you need to go up in weight or class.
Re: Mobil 1 EP 0w-20 10,101 Miles 2016 Accord [Re: Astro_Guy] #5006998
02/10/19 02:56 PM
02/10/19 02:56 PM
PimTac Offline
PimTac  Offline
Excellent comment by SubieRubyRoo.
Cannot see signatures any longer so it doesn’t matter.
Page 2 of 2 1 2
Moderated by  ekpolk
