Quaker State Ultimate Durability $14.99
by SubieRubyRoo. 05/24/19 08:38 PM
Who makes the Thickest 5W-20
by kstanf150. 05/24/19 08:09 PM
Home HVAC question
by FirstNissan. 05/24/19 07:55 PM
Freds Stores brand oil filters
by Electromotive. 05/24/19 07:23 PM
Air filter improperly installed at Walmart...
by jongies3. 05/24/19 07:07 PM
Finally getting Comcast out in the sticks
by rekit. 05/24/19 06:49 PM
Which brand for strut mounts?
by das_peikko. 05/24/19 06:10 PM
HF Chicago Electric DA Polisher Discontinued?
by TheLawnRanger. 05/24/19 05:49 PM
Fram Ultra PentaStar - Canada
by StevieC. 05/24/19 03:46 PM
2019 CRV Recall - Airbags
by StevieC. 05/24/19 03:20 PM
Goodyear GY1100 floor jack
by Patrick0525. 05/24/19 03:17 PM
Brakemotive rotors and brake pads - Any good?
by diyjake. 05/24/19 03:09 PM
How clean is the new oil you use?
by Talent_Keyhole. 05/24/19 12:41 PM
Trans fluid change at 30K??
by flinter. 05/24/19 12:36 PM
Redlines equivalent to RP HPS
by Ivoidwarranties. 05/24/19 12:23 PM
6.0L powerstroke towing with 10w30
by mattd. 05/24/19 11:12 AM
1004ron, Rt188, Sarasmilz77, Indie, NicksGTR
68203 Registered Users
107 registered members (4WD, 1004ron, alchargo, 2010Civic, amblerman, 10 invisible), 1,845 guests, and 24 spiders.
Topics289,356
Posts4,967,759
Members68,203
Most Online2,967
Mar 10th, 2019
Page 2 of 3 1 2 3
Re: Wife's RAV4, burnt clutch, DIY [Re: KrisZ] #5004772
02/08/19 11:48 AM
02/08/19 11:48 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Agree. Nothing good comes of dual mass flywheels. If it's the type with the springs, I bet some are broken.
Re: Wife's RAV4, burnt clutch, DIY [Re: Audios] #5004851
02/08/19 01:07 PM
02/08/19 01:07 PM
Reunion Island
Superflan Offline OP
Reunion Island
Originally Posted by KrisZ
That clutch is toast. A slipping clutch is almost never the fault of hydraulics, unless there is a leak on the clutch, as they are used to disengage the clutch, then the clutch springs engage it and ensure it stays engaged.
I would look for a single mass flywheel conversion kit. It will be less expensive than a dual mass flywheel and should last for the life of this vehicle no problems.
I have receipt of clutch repair at 80000km or so, it's 144000km and toast. 60000km is rather short for a set. The hydraulics were sticking when pressed, I opened and cleaned 2 times because OEM 17 years DOT3 fill was forming gunk in master and slave cylinder. I guess this wore out the clutch prematurely. I could see the fork still moving when pressing pedal and going out of car before cleaning inside
Seems I'm wrong and it's not a DMF (I'll see it live tomorrow)
Originally Posted by Audios
2WD drops it down to 6.7 hours, so heres hoping that its only a front wheel drive?
It's a 4WD
‘01 Peugeot Partner 1.9 D, 5W40 A3/B4, 258000 Km, running on WVO
Wife's ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 148000 Km
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004883
02/08/19 01:50 PM
02/08/19 01:50 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
Originally Posted by Miller88
Originally Posted by supton
Being AWD I could see it being a long job.
IIRC it was about an hour to drop the trans in my Jetta. But my mechanic had done it a bunch of times, knew what he was doing. But no extra driveshaft etc in the way.
Cars suck. Sometimes I think about buying new and flipping every 150-200k (6-10 years, give or take). Not the cheapest solution but perhaps least work involved.
I said I was done with new or even newer vehicles. I figured with a small fleet of older vehicles, I could make it work.
Until all three broke at once
That was recently my situation-GMC developed a pretty big fuel leak (hose under the intake, of course), and the xB’s exhaust decided to fall off. Good thing it was 65F & mostly sunny last Saturday! Had to get them fixed before the XJ or F-450 got any ideas...
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004894
02/08/19 01:59 PM
02/08/19 01:59 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Wow! You learn something new everyday. I never encountered or heard of something like this before. The fluid must've been really gunky to hold off the clutch plate pressure.
Thanks for sharing this.👍
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004908
02/08/19 02:13 PM
02/08/19 02:13 PM
USA
mk378 Offline
mk378  Offline
USA
Sounds like contaminated fluid, in that case the only cure is to replace both cylinders and flush the line well.
Re: Wife's RAV4, burnt clutch, DIY [Re: mk378] #5004935
02/08/19 02:48 PM
02/08/19 02:48 PM
Reunion Island
Reunion Island
Yeah me neither. The gunk looked like blue « marine » grease
I’ll monitor things carefully but now it’s working good
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004942
02/08/19 02:53 PM
02/08/19 02:53 PM
pa
benjy Offline
benjy  Offline
pa
todays clutches being hydraulic generally feed of brake fluid reservoir, at least my 11 nissan frontier does. changing + flushing all fluid is generally every 5 years. can't say anything but good luck + as noted single mass fly + aftermarket can be a lot cheaper, look for you tubes + buy a service manual for specific torques. i would join + look at a Rav IV specific forum as well, good luck!!
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005000
02/08/19 03:52 PM
02/08/19 03:52 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
The OP is in Reunion Island, I doubt there's a HF location close by.
I would try the job myself. Probably need two weekends to get it all done...
Here is a link which may help you. Not sure if any special tools are needed to access everything.
https://pmmonline.co.uk/technical/how-fit-clutch-toyota-rav4/
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005002
02/08/19 03:56 PM
02/08/19 03:56 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Hope it's just a hydraulic issue.
I had something similar with my BMW several years ago. The slave was fed off the master cyl (shared res.) and once the brake fluid went low enough, it caused issues with the slave.
Another vote for FWD/RWD
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005170
02/08/19 07:03 PM
02/08/19 07:03 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I doubt the hydraulics would wear out the clutch, the release bearing and fingers maybe, but not the clutch plate.
I haven't done the later models, but the first RAV4's were a really pain. you can't pull the gearbox back because it hits the transfer box, you can't remove the transfer because it hits the block. In the shop it's easier to drop the powertrain on the floor and jiggle it all apart. A young guy at work did one in the car last year, it looked nasty because he had the engine hanging at an angle to get the box down. Not something I'd do at home that's for sure.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005303
02/08/19 10:01 PM
02/08/19 10:01 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I’d make extremely sure the pressure plate has free play at the fingers. As a clutch disk wears the free play decreases. Replacement parts may have different dimensions and take up any slack faster.
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005374
02/09/19 12:25 AM
02/09/19 12:25 AM
Reunion Island
Reunion Island
New parts
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005624
02/09/19 10:52 AM
02/09/19 10:52 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Wheres Extra EU?
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005659
02/09/19 11:24 AM
02/09/19 11:24 AM
USA
mk378 Offline
mk378  Offline
USA
I read that to mean "somewhere not in the EU." The telephone number would lead to Verona, Italy though.
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5005767
02/09/19 01:47 PM
02/09/19 01:47 PM
Reunion Island
Reunion Island
So, the [censored] clutch kit is out. Rivets were licking pressure plate.
Jack up the car, remove wheels, detach control arms, detach wheel pivots, remove x member, remove front driveshafts, remove half airbox, detach clutch slave cylinder, lines, remove starter motor, jack up engine, remove gearbox, done.
It took 3 hours for me and a brother's friend who did it on his RAV4 weeks ago.
Now I need to shave the flywheel that is in bad shape before putting it all back together
Next on Monday with pics
Page 2 of 3 1 2 3
