Hi,
I maybe underestimated a disaster that was waiting to happen.
When we bought the used car, I noticed the clutch was slipping sometimes, but mainly after engaging each gear.
Later I figured out that hydraulics were the problem, and cleaning slave cylinder (all greasy inside) and flushing fluid solved 80% of clutch behaving issues.
But on occasions, like giving full throttle at sub-midrange RPMs, it slipped anyway until catching up at a higher speed. I then figured that even if clutch pack was replaced somewhere long before the purchase, that hydraulics was likely the root problem and that it continued to wear the actual clutch pack
Fast forward today, it slips at every hill, and I think it won't last more than a work day. I will check hydraulics in a minute to insure it's not sticking.
Any clue of special things when replacing a clutch pack and dual mass flywheel on this MY2001 TOYOTA 1AZ-FE RAV4 ?
