Ford testing new vehicles
by 97prizm - 09/21/19 08:00 PM
Any stuffed pepper lovers here?
by 53' Stude - 09/21/19 06:55 PM
Shrinking Window Tint.
by George7941 - 09/21/19 05:30 PM
Drain and refill or Cooler line flush?
by jrvn - 09/21/19 05:25 PM
Federated Auto Parts 400 at Richmond Raceway
by bdcardinal - 09/21/19 04:40 PM
Stick with OEM or try aftermarket?
by Nav45 - 09/21/19 04:25 PM
Body Shop guys, what should I expect to pay?
by dwcopple - 09/21/19 03:59 PM
What Vehicle and Trailer to Tow Tractor?
by lancerplayer - 09/21/19 03:40 PM
Garage high humidity floor wet vehicle inside.
by littleant - 09/21/19 03:34 PM
[NEW] Carquest 95515 / Fits MB GLA/CLA
by SlavaB - 09/21/19 03:23 PM
KENDALL GT-1 HIGH PERFORMANCE SYN BLEND 5W-30
by OilReport99 - 09/21/19 03:02 PM
Weekend detail
by gregk24 - 09/21/19 02:32 PM
Valvoline Premium Blue 8600 ES 15W40
by 53' Stude - 09/21/19 01:20 PM
Axle shaft seal leak?
by aquariuscsm - 09/21/19 01:14 PM
Refills for Denso Designer wipers
by mclasser - 09/21/19 12:45 PM
What make steering wheel hard to turn
by Rohan - 09/21/19 12:43 PM
Z55 coil spring options
by LeakySeals - 09/21/19 12:28 PM
diy AA Solar charger?
by earlyre - 09/21/19 11:53 AM
OilReport99, TungGT, ErikLeifson, Kinnes25, Bamajoe
69348 Registered Users
94 registered members (ammolab, 4WD, 2015_PSD, 928, 97prizm, 10WSmuckers, 9 invisible), 1,974 guests, and 26 spiders.
Topics294,879
Posts5,068,565
Members69,348
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Wife's RAV4, burnt clutch, DIY #5004508 02/08/19 03:48 AM
Superflan Offline OP
Hi,
I maybe underestimated a disaster that was waiting to happen.
When we bought the used car, I noticed the clutch was slipping sometimes, but mainly after engaging each gear.
Later I figured out that hydraulics were the problem, and cleaning slave cylinder (all greasy inside) and flushing fluid solved 80% of clutch behaving issues.
But on occasions, like giving full throttle at sub-midrange RPMs, it slipped anyway until catching up at a higher speed. I then figured that even if clutch pack was replaced somewhere long before the purchase, that hydraulics was likely the root problem and that it continued to wear the actual clutch pack
Fast forward today, it slips at every hill, and I think it won't last more than a work day. I will check hydraulics in a minute to insure it's not sticking.
Any clue of special things when replacing a clutch pack and dual mass flywheel on this MY2001 TOYOTA 1AZ-FE RAV4 ?
‘01 Peugeot Partner 1.9 D, 5W40 A3/B4, 262000 Km, running on WVO
Wife's '19 Suzuki Vitara 1.0 Boosterjet (TGDI), FACTORY FILL, 6000 Km
Backup's ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 158000 Km
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004531 02/08/19 05:37 AM
G
Gasbuggy Offline
G
I can't tell you any specific things you will need. But I can say that when I was 20 I replaced a clutch into a FWD toyota with a friend of mine who just like myself, had no clue what he was doing. We got it done and it worked.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004614 02/08/19 08:24 AM
A
Audios Offline
A
Youre going to need alot alot alot of time and even more patience. Book time is 18.9 hours for 4wd!!!! This could be a killer for the car depending on how much you want to sink into the car, but we could be in the 3000 range at a shop. Insane!
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Wife's RAV4, burnt clutch, DIY [Re: Audios] #5004625 02/08/19 08:39 AM
18h! Are you sure it's for the same car? Seems overkill
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004640 02/08/19 09:00 AM
Cujet Offline
18 hours for a shop means more than that for someone working on jack stands. Yikes.
Cars are such a pain sometimes. As an older guy, I simply don't have the time or energy to be dealing with transmission removals in my driveway. I truly feel for you.
I'd rather be out on my KTM, misbehaving.......
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004641 02/08/19 09:02 AM
M
Miller88 Offline
M
On vehicles with transverse engines, you have to do a significant amount of extra work.
Front suspension has to come apart to be able to get the axle shafts out. Linkages have to be disconnected (and they are never in good locations). If you're lucky, the transmission can come out the top - otherwise you're dropping a subframe/kmenber/engine cradle/whatever-it-is to get the transmission out. Intake tubes, battery box ... all sorts of junk in the way with transverse engines.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004644 02/08/19 09:06 AM
I'll document it so we can see what we have to see smile it's gonna be interesting
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004647 02/08/19 09:09 AM
supton Offline
Being AWD I could see it being a long job.
IIRC it was about an hour to drop the trans in my Jetta. But my mechanic had done it a bunch of times, knew what he was doing. But no extra driveshaft etc in the way.
Cars suck. Sometimes I think about buying new and flipping every 150-200k (6-10 years, give or take). Not the cheapest solution but perhaps least work involved.
2011 Toyota Camry, base, 2.5L/6MT, 189k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 211k, his
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004652 02/08/19 09:21 AM
Duplicate post
Re: Wife's RAV4, burnt clutch, DIY [Re: supton] #5004656 02/08/19 09:23 AM
M
Miller88 Offline
M
I said I was done with new or even newer vehicles. I figured with a small fleet of older vehicles, I could make it work.
Until all three broke at once
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004677 02/08/19 10:00 AM
B
BigD1 Offline
B
Yes they are a royal PITA.
If the trans comes out the bottom, they will probably need an engine support bar.
https://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
1992 Toyota Pickup--Quaker State Advanced Durability 10W-30--Motorcraft 910S
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004678 02/08/19 10:04 AM
AZjeff Offline
Originally Posted by Superflan
Hi,
We've probably all done that with used cars with varying degrees of work and expense involved to correct the oversight. In another thread someone mentioned a free car that he had $2300 in and wasn't done yet. Ouch.
Grateful I don't have to deal with vehicles in their end of life miles. Hope it all doesn't have to come out the bottom. Good luck.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004682 02/08/19 10:09 AM
supton Offline
LOL Sorry, I can see that happening. MTBF all deciding to hit at once.
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004701 02/08/19 10:29 AM
K
KrisZ Online Content
Online Content
K
That clutch is toast. A slipping clutch is almost never the fault of hydraulics, unless there is a leak on the clutch, as they are used to disengage the clutch, then the clutch springs engage it and ensure it stays engaged.
I would look for a single mass flywheel conversion kit. It will be less expensive than a dual mass flywheel and should last for the life of this vehicle no problems.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004766 02/08/19 11:45 AM
A
Audios Offline
A
2WD drops it down to 6.7 hours, so heres hoping that its only a front wheel drive?
Page 1 of 3 1 2 3
