Maxlife ATF for +4 application
by ZraHamilton. 05/26/19 03:43 PM
PL24651 Purolator One 6K Miles
by kstanf150. 05/26/19 02:38 PM
Inner tube for 700c beater
by MrQuackers. 05/26/19 02:34 PM
New to the cartridge oil filter party....
by ZZman. 05/26/19 11:49 AM
HF dual action polisher
by buck91. 05/26/19 11:22 AM
Virgin Motorcraft 820 Cut Open
by kstanf150. 05/26/19 11:11 AM
M1 EP for '19 F150 3.5 EB
by dseg42. 05/26/19 10:02 AM
Get New HVAC or Keep Old?
by tc1446. 05/26/19 09:48 AM
HF torque wrench wore out
by eljefino. 05/26/19 09:31 AM
garage fridge problems
by zrxkawboy. 05/26/19 08:35 AM
Sudden Unintelligence Syndrome
by AlienBug. 05/26/19 08:27 AM
Cutting Wet Grass
by Snagglefoot. 05/26/19 08:20 AM
Dealer Repair exposed a yellow wire?
by Datarock. 05/26/19 07:14 AM
Transmission Pan Gasket?
by mctmatt. 05/26/19 07:12 AM
Gas Mileage
by Al. 05/26/19 07:11 AM
Why HTHS 3.0 Minimum Is Preferred By Many ?
by ChrisD46. 05/26/19 06:14 AM
Fram Extra CA7597
by mcwilly. 05/26/19 03:26 AM
Carbon knock or piston slap
by i6pwr. 05/26/19 03:11 AM
brycam00, Kingkopra, rschwartz33, Rhoover, chirolla
68214 Registered Users
86 registered members (ARCOgraphite, bdcardinal, 53' Stude, 08z06, 1WildPig, 10 invisible), 2,143 guests, and 22 spiders.
Topics289,429
Posts4,969,352
Members68,214
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Wife's RAV4, burnt clutch, DIY #5004508
02/08/19 03:48 AM
02/08/19 03:48 AM
Reunion Island
Superflan Offline OP
Reunion Island
Hi,
I maybe underestimated a disaster that was waiting to happen.
When we bought the used car, I noticed the clutch was slipping sometimes, but mainly after engaging each gear.
Later I figured out that hydraulics were the problem, and cleaning slave cylinder (all greasy inside) and flushing fluid solved 80% of clutch behaving issues.
But on occasions, like giving full throttle at sub-midrange RPMs, it slipped anyway until catching up at a higher speed. I then figured that even if clutch pack was replaced somewhere long before the purchase, that hydraulics was likely the root problem and that it continued to wear the actual clutch pack
Fast forward today, it slips at every hill, and I think it won't last more than a work day. I will check hydraulics in a minute to insure it's not sticking.
Any clue of special things when replacing a clutch pack and dual mass flywheel on this MY2001 TOYOTA 1AZ-FE RAV4 ?
‘01 Peugeot Partner 1.9 D, 5W40 A3/B4, 258000 Km, running on WVO
Wife's ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 148000 Km
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004531
02/08/19 05:37 AM
02/08/19 05:37 AM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
I can't tell you any specific things you will need. But I can say that when I was 20 I replaced a clutch into a FWD toyota with a friend of mine who just like myself, had no clue what he was doing. We got it done and it worked.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 5w30 Euro L
LR Series III 10w40 VWB
76' 300D Rotella T4
02 Yukon 10w30 PP
10 Charger Pursuit 5.7L
01 P71 with SAP
95 Accord - 386k. Mobil 2 RIP
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004614
02/08/19 08:24 AM
02/08/19 08:24 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Youre going to need alot alot alot of time and even more patience. Book time is 18.9 hours for 4wd!!!! This could be a killer for the car depending on how much you want to sink into the car, but we could be in the 3000 range at a shop. Insane!
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Wife's RAV4, burnt clutch, DIY [Re: Audios] #5004625
02/08/19 08:39 AM
02/08/19 08:39 AM
Reunion Island
Reunion Island
18h! Are you sure it's for the same car? Seems overkill
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004640
02/08/19 09:00 AM
02/08/19 09:00 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
18 hours for a shop means more than that for someone working on jack stands. Yikes.
Cars are such a pain sometimes. As an older guy, I simply don't have the time or energy to be dealing with transmission removals in my driveway. I truly feel for you.
I'd rather be out on my KTM, misbehaving.......
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004641
02/08/19 09:02 AM
02/08/19 09:02 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
On vehicles with transverse engines, you have to do a significant amount of extra work.
Front suspension has to come apart to be able to get the axle shafts out. Linkages have to be disconnected (and they are never in good locations). If you're lucky, the transmission can come out the top - otherwise you're dropping a subframe/kmenber/engine cradle/whatever-it-is to get the transmission out. Intake tubes, battery box ... all sorts of junk in the way with transverse engines.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004644
02/08/19 09:06 AM
02/08/19 09:06 AM
Reunion Island
Reunion Island
I'll document it so we can see what we have to see smile it's gonna be interesting
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004647
02/08/19 09:09 AM
02/08/19 09:09 AM
NH
supton Offline
supton  Offline
NH
Being AWD I could see it being a long job.
IIRC it was about an hour to drop the trans in my Jetta. But my mechanic had done it a bunch of times, knew what he was doing. But no extra driveshaft etc in the way.
Cars suck. Sometimes I think about buying new and flipping every 150-200k (6-10 years, give or take). Not the cheapest solution but perhaps least work involved.
2011 Toyota Camry, base, 2.5L/6MT, 183k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 149k, ours
1999 Toyota Camry LE, 2.2L/4AT, 207k, his
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004652
02/08/19 09:21 AM
02/08/19 09:21 AM
Reunion Island
Reunion Island
Duplicate post
Re: Wife's RAV4, burnt clutch, DIY [Re: supton] #5004656
02/08/19 09:23 AM
02/08/19 09:23 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I said I was done with new or even newer vehicles. I figured with a small fleet of older vehicles, I could make it work.
Until all three broke at once
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004677
02/08/19 10:00 AM
02/08/19 10:00 AM
NC
BigD1 Offline
BigD1  Offline
NC
Yes they are a royal PITA.
If the trans comes out the bottom, they will probably need an engine support bar.
https://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
1992 Toyota Pickup--Castrol GTX 10W-40--ACDelco PF53
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004678
02/08/19 10:04 AM
02/08/19 10:04 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Originally Posted by Superflan
Hi,
We've probably all done that with used cars with varying degrees of work and expense involved to correct the oversight. In another thread someone mentioned a free car that he had $2300 in and wasn't done yet. Ouch.
Grateful I don't have to deal with vehicles in their end of life miles. Hope it all doesn't have to come out the bottom. Good luck.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Wife's RAV4, burnt clutch, DIY [Re: Miller88] #5004682
02/08/19 10:09 AM
02/08/19 10:09 AM
NH
supton Offline
supton  Offline
NH
LOL Sorry, I can see that happening. MTBF all deciding to hit at once.
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004701
02/08/19 10:29 AM
02/08/19 10:29 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
That clutch is toast. A slipping clutch is almost never the fault of hydraulics, unless there is a leak on the clutch, as they are used to disengage the clutch, then the clutch springs engage it and ensure it stays engaged.
I would look for a single mass flywheel conversion kit. It will be less expensive than a dual mass flywheel and should last for the life of this vehicle no problems.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Wife's RAV4, burnt clutch, DIY [Re: Superflan] #5004766
02/08/19 11:45 AM
02/08/19 11:45 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
2WD drops it down to 6.7 hours, so heres hoping that its only a front wheel drive?
Page 1 of 3 1 2 3
