Originally Posted by SonofJoe
Back in the day, I built myself a simple but effective engine oil blending program in Lotus 123. You could put together all the various bits of an oil & it would tell you stuff like KV100, KV40, CCS, KV after KO30, HTHS, Noack, TBN, metals, nitrogen, sulphur & most important of all, it's cost.
If say I wanted to find out what The Competition was doing, I'd get hold of some oil, get it checked out in the lab & then try and make a Chinese copy of the oil in Lotus. You never knew if the copy was correct but my gut feel was they they were always close enough to get some kind of insight. Interestingly it was often the type & amount of VII used by The Competition which I was particularly curious about.
Many (most??) on here still think that
any amount of
any type of VII is "EVIL plastic", and to be avoided,
at all costs due to shearing, etc.
IS that the 'truth', or are there actually modern/'high tech' VII formulations which are NOT all that shear-prone, nor harmful 'evil plastics' as thought on here, and maybe even actually quite
beneficial,
even if quite co$tly in dollar amount?
VIIs are not, and never have been 'EVIL plastic'. In fact, after ZDDP, I'd rank them as THE most useful & effective of all the engine oil additives.
VIIs basically ushered in the age of true multigrade oils at a time when almost all base oils were lowish Viscosity Index Group I minerals. They yield oils that are thin enough to pump at low temperatures & thick enough to limit wear at high temperatures.
It's true that Group IIIs & PAOs have higher VI than minerals but the increase only PARTIALLY reduces the need for VII; it seldom eliminates it altogether. Having a VII-free PAO based 10W30 might be seen as being 'pure' but it's not really going to cut it, if for example, you're trying to drive when there's a polar vortex running riot outside!
One has to be careful about demonising certain aspects of oil additives and at the same time, wilfully ignoring the greater benefit they bring.
THANK YOU!
There was a member on here who was quite 'demonized', and viewed as a pariah on here for believing that there WERE actually very good, all but shear-proof, modern high tech VIIs existing out there, which were used in some of the the top grade, (and
highest VI spec) oil formulations.
