second Betta won’t eat bloodworms
by BossMoss. 04/19/19 01:03 AM
Battery Chainsaw - new purchase
by Shannow. 04/19/19 12:32 AM
PQIA six new 5w20 samples tested (name brands)
by SlavaB. 04/18/19 11:49 PM
MotoTech oil sale @ Fred Meyer
by SlavaB. 04/18/19 11:40 PM
being a luthier/
by koffy. 04/18/19 10:31 PM
2019 GMC Syclone
by oilpsi2high. 04/18/19 10:11 PM
KYB Struts from Rock Auto
by Snagglefoot. 04/18/19 10:10 PM
Thump/slap after rear pinion seal replacement
by HoosierJeeper. 04/18/19 09:55 PM
Dealer bulk oil
by leeaspell. 04/18/19 08:44 PM
Help me identify this tie rod washer
by Klutch9. 04/18/19 08:40 PM
Sears suing Lampert for looting them
by slacktide_bitog. 04/18/19 07:45 PM
Champion COS10575 bypass pressure
by Snagglefoot. 04/18/19 07:39 PM
New oil filter cutter
by kstanf150. 04/18/19 07:26 PM
Cat 435-5142 // 2016 LML duramax
by Shata. 04/18/19 06:52 PM
Free to all: Assassin's Creed Unity (PC)
by Rand. 04/18/19 06:29 PM
AC DELCO "PROFESSIONAL" PF 64 CUT OPEN
by 53' Stude. 04/18/19 05:47 PM
Offset
by jcartwright99. 04/18/19 04:07 PM
Honda Camera Design...FAIL
by Sayjac. 04/18/19 04:02 PM
rotella t4 vs delo
by 1978elcamino. 04/18/19 03:50 PM
fatafox, CurtC, LockCracker, fawkes, Kenzitoz
67848 Registered Users
53 registered members (Astro14, 08z06, 4WD, 87sammy, A1O, 2015_PSD, 7 invisible), 701 guests, and 28 spiders.
Topics287,727
Posts4,933,171
Members67,848
Most Online2,967
Mar 10th, 2019
Some CAS Numbers for MSDS SDS Enthusiasts #5004101
02/07/19 04:29 PM
02/07/19 04:29 PM
Iowegia - USA
MolaKule Offline OP
Global Moderator
MolaKule  Offline OP
Global Moderator
Iowegia - USA
For you MSDS watchers, here are some base oils and additives with CAS numbers with descriptions:
NOTE: The CAS numbers listed are not all inclusive of what is out there, but are basic CAS numbers.
Mineral Paraffininc Base Oil - 64742-54-7; VI of +94 to 120, any group, is a generic CAS number for paraffininc base oils;
Mineral Naphthenic Base Oil - 64741-96-4; VI of ~15.
Mineral Aromatic Base Oil - 64742-03-7; VI of ~185.
Hydrotreated paraffininc, heavy - 64742-52-5
Hydrotreated paraffinic, light - 64742-53-6
PAO's: 68649-12-7, 68037-01-4, 163149-29-9, 151006-63-2, 151006-62-1, 151006-60-9, 157707-86-3 with VII's of +155 or greater:
Some PAO Producers:
Chevron Phillips Synfluid PAO 4 cSt PAO
Exxon Mobil SpectraSyn 4 cSt PAO
INEOS Durasyn 164 4 cSt PAO
Diester - 28472-97-1; VII's average +170.
Polyol Esters:
68441-94-1, Pentaerythritol ester of heptanoic and isopentanoic acids
118685-29-3, Mixed pentaerythritol esters of isononionic and heptanoic acids
77-99-6, TrimethylPropane (TMP)
68515-47-9, 1,2-Benzenedicarboxylic acid, di-C11-14-branched alkyl esters, C13-rich
91050-89-4, Fatty acids, C8-10, triesters with trimethylolpropane (TMP)
VII Copolymers - 127883-08-3
Additives:
ZDDP Type Adds: 68649-42-3, XXXXX-46-6.
Calcium Sulfonates: 61789-86-4
Moly Dithiophosphate - 68958-92-7 or 68958-92-9
Moly Disulfide Powders - 1317-33-5
Here is what happens: EM, Chevron or Shell or whomever will come out with an oil (hydrotreated, isomerized, etc) and have it CAS registered with a different (new) number.
I.E., New oils produced under a specific process may have new CAS numbers.
However, CAS numbers do not necessarily equate to the specific process type.
Some CAS Numbers for Group III
hydrocracked hydroisomerized Group III
178603-64-0,
178603-65-1,
178603-66-2
The designation of Paraffinic, Naphthenic, or Aromatic simply describes the structure of the oil molecule. It has nothing to do with waxes, solvents, or being smelly.
And let's remember that MSDS are Safety Data Sheets and do not reflect the actual formula, only what the Manf. has to declare for safety reasons.
The only limitations we have are the ones we place upon ourselves.
Re: Some CAS Numbers for MSDS Enthusiasts [Re: MolaKule] #5004154
02/07/19 05:37 PM
02/07/19 05:37 PM
WY
sloinker Offline
sloinker  Offline
WY
What if the SDS says non-hazardous materials for up to 99% of the volume. What is a non-hazardous base oil? PAO, ester, straight clear mineral oil? I have always wondered because you see this designation a lot in synthetic oil SDS sheets.
Re: Some CAS Numbers for MSDS Enthusiasts [Re: sloinker] #5004170
02/07/19 05:48 PM
02/07/19 05:48 PM
Iowegia - USA
MolaKule Offline OP
Global Moderator
MolaKule  Offline OP
Global Moderator
Iowegia - USA
Can you point to a specific example?
Re: Some CAS Numbers for MSDS Enthusiasts [Re: MolaKule] #5004186
02/07/19 06:00 PM
02/07/19 06:00 PM
WY
sloinker Offline
sloinker  Offline
WY
https://w3apps.phillips66.com/NetMSDS/ViewPDF.aspx?fileName=829143&Language=EN&IssueDate=7%2F2%2F2015&SubFormat=USDS
I have come across others with this non-hazardous designation since I've joined the site but will have to do some more research to find them again.
Seems that mostly ester based products, whether motor oil or refrigerants or building blocks for drugs/plastics etc. have this non-hazardous or no known hazards stipulation on their sds sheets. I pointed out that I used a charcoal lighter fluid the other night that was ester based with alcohol and smelled fruity/grape like/ winey like other ester products I have come across.
Re: Some CAS Numbers for MSDS Enthusiasts [Re: MolaKule] #5004195
02/07/19 06:09 PM
02/07/19 06:09 PM
Ohio
hallstevenson Offline
Ohio
Haha, I pointed that out to some here and I think I hurt their feelings. They acted like they knew a secret formula for a product "because the SDS lists the ingredients".
Re: Some CAS Numbers for MSDS Enthusiasts [Re: MolaKule] #5004429
02/07/19 10:28 PM
02/07/19 10:28 PM
pa
benjy Offline
benjy  Offline
pa
good info for sure + it seems specific specs are getting less all the time as oil blenders would sooner spend on advertising than a better formulated product. i also see where specs used to come up but no more.
Re: Some CAS Numbers for MSDS Enthusiasts [Re: sloinker] #5004492
02/08/19 01:09 AM
02/08/19 01:09 AM
Iowegia - USA
MolaKule Offline OP
Global Moderator
MolaKule  Offline OP
Global Moderator
Iowegia - USA
Reline 5W30 Euro
I have come across others with this non-hazardous designation since I've joined the site but will have to do some more research to find them again...
The other compounds, 1 and 3 are anti-oxidants and can be skin irritants to sensitive individuals. The middle one is an intermediate compound used in processing or the making of other materials and compounds.
The other 99% of the ingredients are deemed non-hazardous and they are under no responsibility to tell you what they are, since the formulae are proprietary.
