Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
56 registered members (69Torino, Astro_Guy, alarmguy, AndyB, Aero540T, 2015_PSD, 5 invisible), 684 guests, and 51 spiders.
Topics284,589
Posts4,872,986
Members67,294
Most Online2,548
Feb 16th, 2019
Oil additive for 18 GT #5003891
02/07/19 11:38 AM
02/07/19 11:38 AM
Louisiana
boosted2v Offline OP
Louisiana
I recently bought an 18 Mustang GT with the 5.0 and many people are having ticking issues already. I am looking to prevent this. In many cases, this is a bottom end problem causing cylinder wear. There are quite a few guys saying Ceratec quietened the engine down. I'm looking to get some suggestions on a good additive that will reduce friction and provide a good layer of film that is resistant to high pressure/sheering without having any detrimental effects or corrosion issues.
Re: Oil additive for 18 GT [Re: boosted2v] #5003901
02/07/19 11:48 AM
02/07/19 11:48 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I would use a quality synthetic oil (that meets the specs) and no additives. If its still making a noise, go back to the dealer. Should be under warranty. Don't ignore the info in the owners manual as to viscosity & temp.
2015 Ford F250 w/Powerstroke
Re: Oil additive for 18 GT [Re: boosted2v] #5003909
02/07/19 11:54 AM
02/07/19 11:54 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
The 5.0 makes many "odd" noises and has for years. First off is to determine which noise you have. Then I'd go to the dealer first with your concerns and get them documented.
If you have the BBQ tick (which goes back to all years of 5.0) Ceratec seems to help. But I'd still get it documented as some have found excessive crank clearances and get new engines.
If you have the light acceleration 1900-2500 RPM rattle it could be fuel system (my guess), out of round bores that cause scoring and oil consumption. Many have this rattle but few engines the scoring. It's present on the F150 too.
Re: Oil additive for 18 GT [Re: boosted2v] #5003926
02/07/19 12:08 PM
02/07/19 12:08 PM
VA
thastinger Offline
thastinger  Offline
VA
Not saying this will help...but in my 13 GT500, which is the 5.8 trinity motor, without the VVT. I run RP HPS 5-30 not the 5-50 which ford calls for.
I don;t track the car or abuse her. The bearing tolerances are the same as my other two 5.4 2V motors which spec a 5-30 oil. I called Shelby on this and they said "Yes, we only speced the 5-50 because people could track the car, if you're not tracking/racing the car you're correct on using 5-30"
Re: Oil additive for 18 GT [Re: boosted2v] #5003941
02/07/19 12:26 PM
02/07/19 12:26 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
XL-17 is the additive number for a tick on a 5.0. We have sold it once back in 2011. FWIW my car has had the tick since new and mine has only had 5W50 since it is a Track Pack.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Oil additive for 18 GT [Re: boosted2v] #5003952
02/07/19 12:43 PM
02/07/19 12:43 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
As said document any noise at the dealer, in writing.
After that no additives but use a good 5w30 oil, or even 10w30, and keep driving. Skip the 5w20 at least 1-2 oil change sot see if that helps.
yup
Re: Oil additive for 18 GT [Re: boosted2v] #5003962
02/07/19 12:56 PM
02/07/19 12:56 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Sorry to hear you have this engine noise but how can one expect an OTC additive to fix an engine design issue?
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Oil additive for 18 GT [Re: MolaKule] #5003964
02/07/19 12:59 PM
02/07/19 12:59 PM
New England
gathermewool Offline
New England
What's the point of ANY OTC additive, in that case?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Oil additive for 18 GT [Re: gathermewool] #5004020
02/07/19 01:53 PM
02/07/19 01:53 PM
Houston, TX
czbrian Offline
czbrian  Offline
Houston, TX
To take money from your pocket and add it to theirs! grin
2006 Honda Pilot
1998 Chevrolet C1500
1995 Chevrolet C1500
2018 Mitsubishi Outlander PHEV
Re: Oil additive for 18 GT [Re: boosted2v] #5004130
02/07/19 04:02 PM
02/07/19 04:02 PM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Depends entirely on what is causing the "tick" as to whether or not an additive will quiet it down or have any effect at all. Additives that really work and are not snake oil are few...
ARCHOIL 9100
LiquiMoly MoS2
Ceratec
And don't put any 5W20 in this motor! Yea yea I know the thin oil guys will yell but this is a very high output/liter engine that will turn decently high RPM. Keep at MIN a 30wt in the sump!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: Oil additive for 18 GT [Re: boosted2v] #5004144
02/07/19 04:22 PM
02/07/19 04:22 PM
Canada
addyguy Offline
addyguy  Offline
Canada
If you had to use an additive, I'd use MoS2. The plating action should cushion mis-fitting parts and reduce wear.
But...I'd hesitate to use it on a brand-new engine under warranty. Problem crops up, it 'may' cause complications...it 'may'...
2010 Kia Soul 2U - 2.0L I-4, auto; 139k miles.
M1 EP 10W-30; OEM Kia filter.
Re: Oil additive for 18 GT [Re: boosted2v] #5004177
02/07/19 04:52 PM
02/07/19 04:52 PM
WY
sloinker Offline
sloinker  Offline
WY
Re: Oil additive for 18 GT [Re: boosted2v] #5004203
02/07/19 05:16 PM
02/07/19 05:16 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I use 5W-30 NAPA synthetic in my 2018.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Oil additive for 18 GT [Re: MolaKule] #5004230
02/07/19 05:38 PM
02/07/19 05:38 PM
California
mbacfp Offline
mbacfp  Offline
California
There is the direct injection tick (which is normal) then there is that bottom end metallic sounding tick (assuming you are referring to that). Have heard it in person and not sure what it is? A youtuber tried Ceratec and tick apparently came back...also did a UOA and wear wasn't out of Blackstone ranges. Not sure what to make of it. It would concern me as an owner...not sure an additive will fix this as Molakule stated.
Edit - Sorry you are looking to prevent it...how many miles you have on it?
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Moderated by  ekpolk
