We bought it used , in June of 2017 .
First thing , I started flushing brake fluid and power steering fluid with a turkey baster . Then I ordered the heater and radiator hoses , serpintine belt , tstat , air and cabin filter . Then I found out about the plastic coolant elbows ( what a crazy idea ! ) .
Lost about a gallon of coolant when I pulled the lower radiator hose . When I got finished replacing the other parts , I went to Wallmart and purchased a gallon of Zerex DEXCOOL spec coolant and filled the system back up & " burped " it .
So , it has ~ 1 gallon of new coolant and the remainder is what ever DEXCOOL was in it , when we acquired it . Only reason I knew it was DEXCOOL is because it is orange .
That year , I think , I dumped a gallon of DEXCOOL on our 2015 Chevy Sonic and replaced it .
I am hoping , changing out 1 gallon at a time , ever couple of years , will be fine , on both cars .
We also have a low mileage 1991 Chevy Caprice , but it rarely gets driven . It has green coolant in it , that was mostly changed , several years ago .
Thanks ,
