Used it for awhile in my tuned VW GTI, and had very good results with it. UOA had super low wear and nitration numbers and handled fuel dilution like a champ. Had one small issue that may or may not be attributable to the oil. Had CEL for implausible signal from VVT and could have been from viscosity drag in the tiny orifices of the unit. Seems to have been a known issue for some and an oil change resolved the issue which is what others have done as well. Switched at that time to the Castrol 0W-40 and never had the issue again for the past 30K. Switched mainly for cost and availability reasons, but UOA on this oil showed almost exactly the same results as the RLI. If I couldn't source the Castrol, and wanted to go back to another "boutique" oil, there would be no question RLI is on the the short list. Just make sure to get the Super High Performance low ash version.
