How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
104 registered members (28oz, 03cvpi, 53' Stude, 55hambone, 2003f7, 2K2AcuraTL, 11 invisible), 2,263 guests, and 16 spiders.
Topics301,618
Posts5,199,201
Members70,742
Page 2 of 15 1 2 3 15
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002131 02/05/19 03:01 PM
CT8 Offline
Push rod engines are nicer.
2015 F150 2.7
2018 F350 6.2
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: racin4ds] #5002136 02/05/19 03:10 PM
H
hatt Online Content
Online Content
H
Originally Posted by racin4ds
This should be a HORSE of an engine. Fords V10 was only a 6.8L mill if I recall. The Biggest gas truck engine to date was the GM 8.1L I just don't see the need for such a large gas engine that will undoubtedly get horrible economy. Why not just buy a diesel if you require this much towing capability?
My notoriously hated 05 PSD with the 6.0 averaged 15-16-mpg loaded to the gills hauling a 3 horse trailer with living quarters, 3 fat mares, tons of excess junk and other items when we moved from WV to Florida, over 975 miles.
Not everyone hauls 20k lbs every day. A more powerful gasser is the ticket. The operating cost are much higher for a diesel. Back when diesel was cheaper than gas you may have made the numbers work. Now diesel is $.60-.80 higher than gas. Never mind DEF, particulate filters, and all the other nonsense on diesels now.
I also had a 6.0. It was used to pull duel tandam 20k trailers every day. It got less than 10 mpgs pulling a load. I'm going to question your loaded mpg numbers.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002138 02/05/19 03:12 PM
Z
ZX11Rebel Offline
Z
The pushrod engine came after OHC engines. So,OHC engines are out of date:)
18 Harley FXLR
15 Ram 5.7 Hemi ZF
07 Pontiac G5GT
07 GMC Canyon 3.7
07 Mustang GT Tr3650
07 Honda Rebel
99 Mazda Protégé ES
99 Kawasaki ZX11
93 ChevyP'up 5.7
75 Sleekcraft 455 olds
63 Cessna Skylane
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: racin4ds] #5002144 02/05/19 03:14 PM
02SE Offline
I guess that depends on your criteria. GM has had 637 CI V8, and 702 CI V12 gas truck engines. Albeit in medium duty trucks.
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002146 02/05/19 03:16 PM
grampi Offline
Big cubic inch pushrod motors rule!
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002161 02/05/19 03:40 PM
U
user52165 Offline
U
FWIW - Over 100 million SBC engines have been built............................
and still being built today.
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy. It's inherent virtue is the equal sharing of misery.
Winston Churchill.
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002179 02/05/19 04:05 PM
E
E365 Offline
E
This will probably be an amazing engine-swap down the road once they hit the junk yards in crashed trucks. Iron block, port injection, 7.3 liters plus an aftermarket twin turbo kit. Massive power and torque!
Whatever's on sale...
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002184 02/05/19 04:07 PM
1
14Accent Offline
1
Looks to be a beast, I would say 500 horse 575 torque are modest estimates. Big displacement, likely long stroke, cast iron block with cross-bolted mains and a gear-driven timing setup with VVT. I dig it.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002192 02/05/19 04:18 PM
DoubleWasp Offline
Commercial operators are going to love this engine (assuming it proves reliable).
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002209 02/05/19 04:42 PM
N
nthach Offline
N
It almost looks like a carbon copy of the SBC too, unless Ford went back into the history books and looked up the 5.0/5.8L OHV V8s they made years ago.
And I thought Ford was a big proponent of overhead cam power too?
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: nthach] #5002222 02/05/19 04:58 PM
O
OVERKILL Online Content
Online Content
O
I don't find it bears any resemblance to the SBC? It doesn't have siamesed ports, if anything I think it looks more like the FR9:
[Linked Image]
Considering the inspiration for the Modular was the 427SOHC, I don't think it would be surprising if their efforts for another pushrod mill resemble the Windsor.
And yes, Ford has put a lot of effort into OHC V8's since the 1990's, but they have brought with them their own suite of issues.
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: hatt] #5002224 02/05/19 04:59 PM
V
Vern_in_IL Offline
V
Diesels were literally regulated out of the market! Started with Low Sulfur fuel, idiots didn't want to see Big Rigs rolling coal, and yes diesel should be cheaper than gas.
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: nthach] #5002229 02/05/19 05:03 PM
bdcardinal Online Content
Online Content
They are for the most part. However trying to make a tall deck big bore DOHC V8 isn't very do-able in any modern application as far as packaging goes.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: double vanos] #5002247 02/05/19 05:23 PM
J
joekingcorvette Offline
J
I like push rod engines and this looks like a winner! It looks like the spark plugs are easy to change. banana
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Fords new 7.3 liter engine is a pushrod engine? [Re: OVERKILL] #5002253 02/05/19 05:28 PM
Online Content
[Linked Image]
slobber the FR9 is so sexy. They have one at the NASCAR Hall of Fame and I was fogging the glass looking at it.
