Have you every wondered why Euro cars suffer from so many electrical issues and copious amounts of plastic components which undergo catastrophic failure? IMO the primary driver behind that is the EU-End of Life Vehicle Directive of 2000. Basically the end result is a vehicle of which upwards to 85% can be easily recyclable or 95% recovered. This also impacts makes sold in other jurisdictions because manufacturers use the same parts across all markets. So now you know why your vehicle uses that garbage material for the valve cover/oil pan gasket.
https://eur-lex.europa.eu/legal-content/EN/TXT/PDF/?uri=CELEX:02000L0053-20130611&qid=1405610569066&from=EN
Something to chew on.
