This stuff is $17 a quart.
"Much like the engine that powers your POLARIS vehicle, POLARIS gear cases are precision engineered using multiple components not found in standard transmissions or gear cases. POLARIS gear cases utilize drive chains, hypoid, helical, spur, and spiral cut gear sets that require specific lubrication. POLARIS' gear cases job is to transmit the engines power efficiently and effectively while absorbing extreme shock loads from the drivetrain. AGL's extreme pressure additive system provides a lubricating film that reduces friction and protects gear sets from heavy shock loads and wear. AGL's unique light viscosity optimizes cavity flow and provides superior chain and bearing lubrication in all climates and conditions. No other gear case oil on the market is designed to protect POLARIS gear cases like POLARIS AGL."
Looks like a cheap synthetic engine oil to me... Would you pay the $17 a qt or switch to a cheaper synthetic 5w30?
