Shouldnt have to add water/coolant..its a sealed system.. here is a TSB for your vehicle..
3/30/2018 6275 - 2015-2018 Various Vehicles - 2.0L EcoBoost - Engine Runs Rough With Diagnostic Trouble Codes (DTCs) P0300, P0301, P0302, P0303, P0304 And/Or P0316
Some 2015-2018 Fusion/MKZ/MKC/Escape/Edge vehicles equipped with a 2.0L EcoBoost engine may exhibit a runs rough condition with DTCs P0300, P0301, P0302, P0303, P0304 and/or P0316. This may be due to coolant intrusion due to corrosion on the engine block. To diagnose this concern, with the engine at normal operating temperature, pressurize the cooling system to 138 kPa (20 psi) and hold for 5 hours. If the coolant pressure drops 27.57 kPa (4psi), remove the spark plugs and inspect for coolant in the cylinders. If coolant is found in any of the cylinders, replace the engine long block assembly. Follow normal prior approval process for your Dealership. However, follow the diagnostic repair procedure in this article to determine correct repair. For claiming, use causal part 6006 and applicable labor operations in Section 6 of the SLTS Manual.
