Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
17 registered members (Danno, Brynjaminjones, edhackett, domer10, Char Baby, blufeb95, 1 invisible), 580 guests, and 28 spiders.
Topics307,388
Posts5,309,615
Members71,821
Front/Rear brake balance #4999416 02/02/19 12:40 PM
Danh Offline OP
My 2017 Acura TLX seems to have brake balance very heavily biased to the front. While some of this is normal in fwd vehicle in my case it seems extreme: rust on rear rotors from rain can persist for weeks even with regular brake use.
I’ll take it in to the dealer but expect the usual “it’s normal, please leave” routine. Is there a way a dealer can dial in more rear brake bias? Is there a way brake balance can be tested? I’d like to see the dealer with some level of knowledge and appreciate any help offered. Thanks.
Re: Front/Rear brake balance [Re: Danh] #4999450 02/02/19 01:12 PM
Dave1027 Offline
Rust on the pad contact surface? I'd jack up the rear wheels, spin them and have somebody hit the brake to see if they are working.
Re: Front/Rear brake balance [Re: Danh] #4999466 02/02/19 01:33 PM
M
Mainia Offline
M
Welcome to the club!!!, I have /kind of had -the same problem on my 2018 AWD Kona 1.6T. I worked with my dealer day time service manager ( he knew me from my 14,000 mile Hyundai Elantra semi common bearing/piston issue warranty rebuild) so he worked with me more freely. We went for braking run in mine and then new Kona's and took laser rear disk temps. Mine was about 100 deg less but mine were more broken in so less heat. My comment was I can't get my rear brakes "blued" color or bedded properly because I have such bad rear brake bias. That's how I myself was attacking it, more in the sport driving way. He said call Hyundai if you want to take it further. So I did and you have to use the key words to get it elevated " I don't feel safe in my car, I fear for my safety" and like a light switch they started a file on my car to be elevated and I got NO WHERE. An asian lady could of cared less after 10 minutes of selling my problem. They looked at it as long as slow grandma and grandpa can stop , we don't care about you.
My sub compact SUV/crossover handles good for the average person but I raced cars when younger so I expect more. The Kona would nose dive and the rear would lift in panic braking and sport braking so it would not have enough weight in the rear to use the rear for braking. The Kona AWD has big swaybars but a kinda soft spring rate for a nice ride. Your TLX should be way stiffer. My simpleton Elantra GT was a semi soft sprung car but would not dive or lift in the rear and had GREAT rear brake bias. You would feel the rear braking all the time and it stopped on a dime for a simpleton with a 1.8 liter non turbo car.
I have to assume your car is stiffly sprung like my Honda Fit was. I was going to buy Eibach lowering springs anyway so I ordered them right away and that stopped my front dive and rear lift issue. It seems the Kona had very stiff shock valving with softer springs which make it handle OK but when pushed it dives and lifts. Adding the Eibach lowering spring gave me the increased spring rate, and no need for Koni's or Bilstein's since the stock struts are way stiff and a perfect match for the new springs. It still is not the correct rear brake bias but it is 60% better and livable now. My old tricked out Audi's and VWs you could adjust the rear bias since they were before ABS. I owned a hobby Audi repair shop out of my large when I was younger, so I know cars.
The dealer you went to, you might as well forget them, next you need to call Acura and use those famous words above and get it elevated at the next closest dealer. Have they even bleed the brakes yet??? If you come up short with Acura after being a throne in their side (keep whining nicely) You can always try getting new "slotted" rear brake rotors. NOT drilled. Drilled can crack too easy. I am doing this with my Kona once more after market brake companies come up with them since the rears on mine have never been used before on any car since it is a new platform design. The fronts are Hyundai Veloseter Turbo brakes so those have been around for a while and available. I am partial to EBC with their nice rotor coating.
Here you go for your car. call EBC tech line and get an opinion on what color pad to use for your situation. You should use their pad on their rotors because they have a hard coating and they have special abrasives on the pad to clear it off. And be HARD on your brakes because rear brake take some hour time to break in, way more then the front.
https://www.autoanything.com/brakes/ebc-ultimax-rotors
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Front/Rear brake balance [Re: Danh] #4999497 02/02/19 02:08 PM
A
andyd Offline
A
Going to a stiffer front shock is enough to the situation ? Makes perfect sense
Thick oil is better grin2
Re: Front/Rear brake balance [Re: andyd] #4999502 02/02/19 02:14 PM
M
Mainia Offline
M
a TLX is plenty stiffly sprung and valved. He won't have the problem I had. I would elevate it with Acura corporate and go to a different dealer and do what you have to if they keep denying the issue like mine. There is something more wrong with his since it is Acura's cheap (ha ha) high performance sedan and it is classified as a performance car.
2005 Honda Civic
Re: Front/Rear brake balance [Re: Danh] #4999543 02/02/19 03:19 PM
A
anndel Offline
A
In physics, the majority of stopping power is in the front versus the rear. About 80-90% of braking/stopping a rear OR front wheel drive vehicle is at the front brakes. That's why some cars/trucks you have disc brakes in the front and cheaper drum brakes in the rear.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - Amsoil SS 10W-30, Amsoil FIlter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Front/Rear brake balance [Re: Mainia] #4999587 02/02/19 04:07 PM
Dave9 Offline
Originally Posted by Mainia
My comment was I can't get my rear brakes "blued" color or bedded properly because I have such bad rear brake bias...
... That's how I myself was attacking it, more in the sport driving way.
No, that is a sign you're overheating your brakes. Nobody needs to try to turn their vehicle into a pretend-race-car to have it work as engineers intended. Recognize public roads are not a race track and drive responsibly. Pick a different vehicle if you cannot drive the same things everyone else does. Good driving, opposed to trying to take a corner as fast as possible to win a race, does not require stopping fast enough that the front of a softly sprung vehicle transferring weight will matter much. It is considered in the design.
The correct approach to this is to have a technician familiar with the braking system (or enough life experience to know what s/he is looking at), test drive, pull the wheel, inspect lines and hoses, check rotor and pad wear and overall condition, check slider rails, check slider pins... see if anything is really wrong or if there is just an expectation that rust should be removed faster than it is.
Remember, so far that is all we know, nothing was mentioned about "it won't stop". Ultimately for us to give any sound advice over the internet we'd need a lot more information after someone has inspected the braking system, including just how much rust there was, how much remains after a reasonable length drive, including good pictures with the wheel off before and after the initial rust observation from sitting and the drive.
Re: Front/Rear brake balance [Re: Danh] #4999635 02/02/19 05:06 PM
M
mightymousetech Offline
M
Just curious. When was the last time the rear brakes were serviced? VERY important to do them at least once a year. The rear rotors are showing corrosion because the pads are probably seized in the caliper brackets.
FYI, I was an Acura dealer tech for 13 years.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition PPE 5W40 MTL/MT-LV
2010 BMW 328i X-Drive, PPE 5W40 MT-LV
Re: Front/Rear brake balance [Re: mightymousetech] #4999660 02/02/19 05:31 PM
Danh Offline OP
You could be right, but the car is less than 2 years old and hasn’t been subjected to much salt. Seems early for that kind of issue. After owning 20+ cars this would be a first for this stage of ownership.
The car does stop, but since new instead of the pedal being high and hard it’s been a little low and soft. Maybe the issues are related?
Re: Front/Rear brake balance [Re: Danh] #4999679 02/02/19 05:46 PM
M
M
I
Two years old and the brakes have not been serviced? Eek! You are lucky the pads are not metal on metal by now. The first brake service is the most important as the brakes are too tight and not enough lube from the factory. Pretty common to see the pads half worn by the time the first B service is due.
Just FYI, I service my own brakes every oil change, which I do every 5000 km. The rear brakes on Honda/Acura seize very quickly.
And yes, I would say it is related. Pads probably have tapered wear. Has the vehicle shown due for a type B service yet?
Mighty Mouse Tech
Re: Front/Rear brake balance [Re: Danh] #4999688 02/02/19 05:53 PM
T
Tman220 Offline
T
One thing I think people often overlook when they try to "fix" their brakes or try to make them better is they will put a higher friction coefficient pad on the front of their vehicle without matching it on the rear. What do you think happens when a car was designed for FF pads front and rear and someone decides to put GG pads on the front without also putting GG pads on the rear? Bias would certainly shift forward in that case. If you want to shift bias sightly to the rear putt FF's in the front and GG's in the rear.
But I would guess that 99% of vehicles should be balanced appropriately by matching brake pad coefficients front and rear.
I just dealt with that on my daily driver Civic, the clown previous owner putt GG pads on the front and those were quick to overheat with very little heat in the drums. I put FF pads in the front like was intended and now my brakes are far more balanced.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 170k
2004 Civic LX M5 190k
2007 Camry 2.4 250k
2016 Victory Vegas
Re: Front/Rear brake balance [Re: mightymousetech] #4999697 02/02/19 06:02 PM
Danh Offline OP
I
Visually, there’s tons of pad life left as it should be with about 13,000 miles. And given the brake feel has been this way since new I doubt pad wear is the culprit. But I’m suitably chastised and will see my (largely incompetent) dealer for the likely shoulder shrug. Thanks for the input.
Re: Front/Rear brake balance [Re: mightymousetech] #4999735 02/02/19 06:54 PM
H
HangFire Offline
H
I don't know about "metal on metal" as my Honda Pilot's rear brake pads have lasted 97K, 66K and 52K, but I can attest to the fact that the rears can seize quickly. I've been advocating annual brake checks and lubes due to harsh de-icing chemicals used in the Rust Belt, but I let mine go 2 years 10 months and found the pins stuck and the pads wearing unevenly.
Various musings: http://hangfire.net
Re: Front/Rear brake balance [Re: Dave1027] #4999740 02/02/19 07:06 PM
H
HangFire Offline
H
Yeah that's not right. If the pistons are functioning at all, even 90%10% split, they should at least clear the rust. I think they're locked up. They may be locked up on one side, that is, piston/inside side pad doing all the braking and the outer pad just sitting there.
Re: Front/Rear brake balance [Re: Dave9] #5436561 05/23/20 08:34 AM
M
Mainia Offline
M
Dave9, blue brakes don't necessarily mean they are overheated. I work with a guy that has a ZL1 Camaro with silver non blued rotors. Every other Camaro I have seen has blue rotors, I might add. He drives like you Dave, I said use that car, why even own it if you drive it like Dave. I looked at every car in my place of works parking lot, 40 cars. All makes from junk to a Mercedes. 90% of them had blued rotors. 50% as blued as mine are. How can 90% of the cars be overheating their rotors? I would of thought the engineers have taken in account the vehicle use, weight, and disc size, and pad material choice as you seemed to of stated. I do have time with car since I owned a hobby Audi repair shop with 60 customers years ago, and now am the maintenance guy at a mid sized printer with 3 buildings. I do have "some idea" how stuff works.
Dave9, your "Mr Rogers" way at looking at the automobile industry and car design are just that, from the eyes of Mr Rogers. Maybe you should take a trip to the SEMA show to learn your comment is moot about "how the engineers intended". Changing a family "wallow bucket" car that Mr Rogers finds "calming to drive" can be changed over and made into a well engineered/advanced sport street car, to autocross car, to a full blown race car with ease. It is done daily by millions of people all over the world. Your wish on perfect slow driving everywhere will never happen. We see this "sport" performance driving in automobile advertisements 35%+ of the time. It's part of our culture, gone are the early 80's of 150 hp 301 V8 Pontiac Trans Am's, and Chevy Chevette's can't shift into 4th gear if the tire pressure is too low.
I choose very carefully where I sport drive, NEVER in residential streets, mostly hwy exit ramps, industrial parks on weekends/nights, and I never go over what I and the car can do though 57 years of sport driving. Do I brake hard, in a very aggressive/race style way, yep, that's how you brake in sport driving. I have my car dialed in with added anti-dive geometry and have balanced out my rear bias just from the lack of reducing weight transfer. I now have blued rear rotors A stock Hyundai Kona has HORRIBLE brake bias in an emergency stop, especially for the average driver. Very dangerous in my opinion. Hyundai chose to have a softly sprung, higher dampened car with large swaybars. That style car design is very highly conducive to nose dive and rear lift with almost no rear brake to road engagement as the ABS will cycle the rear bakes to almost 98% non use. I know, I tested 5 different Kona's at the dealer with the service manger. yet my 2013 Hyundai GT (slow nothing special) had superb rear brake bias.
Why did I chose the Hyundai Kona AWD 1.6T, and lowered it 2 inches and not a Corvette or Audi S3 Sport? I like oddball quirky AWD cars and like to build them to my liking. It does 0-60 in 6.6 seconds stock, but mine is a hair quicker. AWD drive is great in the corners, as we can see here. A game changer. I will start it mid video and watch for 5 minutes.
https://youtu.be/p10m0Jdk8tc?t=445
2005 Honda Civic
